06-13-2011 01:01 PM - edited 03-04-2019 12:42 PM
I am trying to configure a UCS 520 and need to setup the VLAN for the phones. I tried to use the vlan command from the config prompt and also from the vlan database and each time I get the following message:
UC520(vlan)#apply
% not enough space on flash to store vlan database. trying squeeze...
% error squeezing flash - (Operation not supported on this file)
Error on database apply 40: NV storage failure
Here is what my nvram is showing:
UC520#dir nvram:
Directory of nvram:/
246 -rw- 6461 <no date> startup-config
247 ---- 1933 <no date> private-config
248 -rw- 6461 <no date> underlying-config
1 -rw- 577 <no date> IOS-Self-Sig#1.cer
2 -rw- 0 <no date> ifIndex-table
3 ---- 61 <no date> persistent-data
262144 bytes total (250626 bytes free)
06-13-2011 01:26 PM
There is no need to enter vlan configuration mode. It's all automatic.
06-13-2011 07:27 PM
I am trying to add vlan's and I cannot do it either way. When I try to add a new vlan this is what I get.
06-14-2011 02:25 AM
Again: just configure vlan interface, and that's it.
08-30-2011 08:31 PM
Got the same issue on 3845 router.
If you don't create vlan, interface vlanx stays down.
This command configures vlan-switch on 4ESW card.
Tried booting without config, tried erasing and formatting flash, doesn't help.
sykt-pervm-3845#conf t
Enter configuration commands, one per line. End with CNTL/Z.
sykt-pervm-3845(config)#vlan 5
sykt-pervm-3845(config-vlan)#^Z
Error exiting config-vlan mode 40: NV storage failure
sykt-pervm-3845#
