Is this a valid access-list ????
ryel.dsouza
Is this a valid access list if i want to permit multicast traffic from a particular multicast group while denying the rest
I want to permit traffic from 226.0.0.0 - 238.255.255.255
"access-list 13 permit 226.0.0.0 12.255.255.255"
9 Replies 9
viyuan700
Level 5
Level 5
i think shd be
access-list 13 permit 226.0.0.0 15.255.255.255
but it would permit past 238.0.0.0 like 239.0.0.0 and so on
"but it would permit past 238.0.0.0 like 239.0.0.0 and so on"
it will just go to 239.255.255.255 not further but you dont have a perfect block to use one access list, i think you can break into more access list to be specific
Danilo Dy
Your ACL is invalid.
This ACL will work
This will permit 224.0.0.0 - 239.255.255.255
but it will permit all the networks of 239.0.0.0 - 239.255.255.255 also
i was also thinking
access-list 13 permit 226.0.0.0 7.255.255.255
access-list 13 permit 234.0.0.0 3.255.255.255
You can do this
access-list 13 permit 226.0.0.0 1.255.255.255
access-list 13 permit 228.0.0.0 3.255.255.255
access-list 13 permit 232.0.0.0 3.255.255.255
access-list 13 permit 236.0.0.0 1.255.255.255
access-list 13 permit 238.0.0.0 0.255.255.255
First is 226.0.0.0 - 227.255.255.255
Second is 228.0.0.0 - 231.255.255.255
Third is 236.0.0.0 - 237.255.255.255
Fourth is 238.0.0.0 - 238.255.255.255
Giuseppe Larosa
Hello Ryel,
you need to think in binary to build the correct wildcard mask and to see if one entry is enough
226 = 1110 0010
238 = 1110 1110
but you want permit 237 or 227 also that are even.
so the last bit can be 1 in some cases
so you need to collect common digits
226 = 1110 0010
227 = 1110 0011
one line 226.0.0.0 1.255.255.255
228 = 1110 0100
229 = 1110 0101
230 = 1110 0110
231 = 1110 0111
one line 228.0.0.0 3.255.255.255
232 = 1110 1000
233 = 1110 1001
234 = 1110 1010
235 = 1110 1011
one line 232.0.0.0 3.255.255.255
236 = 1110 1100
237 = 1110 1101
one line 236.0.0.0 1.255.255.255
238 = 1110 1110
one line 238.0.0.0 0.255.255.255
so you see you need multiple lines
Hope to help
Giuseppe
I believe that there is an important aspect of this that has not yet been addressed. Ryel phrases his requirement as being traffic from a multicast group but the multicast address would be the destination address. Multicast traffic is traffic from a unicast source to a multicast group. A standard access list such as access list 13 can only check the source address. If Ryel wants to restrict traffic to particular multicast groups then the access list needs to be an extended access list so that it can check the destination address.
Rick
Rick
Hello Rick,
thanks for pointing out the most important aspect: I thought it was an ACL to use with an RP not to filter traffic you are right in that case an extended acl has to be used with destination field = multicast group
Best Regards
Giuseppe
