ISAKMP on Cisco 877 router
whiteford
Hi, I have a Cisco 877 configured in VPN mode to connect to a Cisco Concentrator. The ISAKMP policy is AES-256/SHA and DH group 5.
Now first of all the 877 will only connect as a VPN if I set both the concentrator and 877 to DH Group 2 and when I look at the session info the ISAKMP is using AES-128/sha? Why not AES-256?
Your IKE Session encryption is aes-128 and DH Group 2, IKE Policy configuration. While your IPSec Session encryption is AES-256, AES Transform Set configuration.
In your "crypto isakmp policy 1", "encr aes" means "encr aes-128". Use "encr aes-256" instead of "encr aes" only. and use DH Group 5. i.e.
encr aes-256
authentication pre-share
group 5
Dandy
7 Replies 7
lamav
Level 8
Level 8
can you post the configs for both boxes for us?
Hi, the Cisco 877 is:
encr aes
group 2
crypto isakmp key ********* address 1.2.3.4
crypto ipsec transform-set T_Set esp-aes 256 esp-sha-hmac
crypto map Crypto_Map 10 ipsec-isakmp
set peer 1.2.3.4
set transform-set T_Set
match address 101
I want to use DH 5 on the above though.
The Concentrator is webbased only (unless I'm wrong) but here is the configuration for the above:
Authentication = ESP/SHA/HMAC-160
Encryption = IKE-AES256-SHA
IKE Proposal = IKE-AES256-SHA
Hi:
Im confused about one thing...
On the 877, you have DH group 2 configured, not 5. So why are you surprised that the connection comes up with a DH 2 sa?
encr aes-256
group 5
Dandy
Dandy I will try this and let you know tomorrow, looks like I've been an idiot!
You're not an idiot.
Good luck.
Victor
That fixed it!!
All my Cisco 877's and 1841 are using the new settings now. Only my 837's are not as they don't seem to be able to do aes.
