12-06-2012 08:27 AM - edited 03-04-2019 06:20 PM
Hi Techs,
I am facing issue with ISDN active calls (incoming only). I have cisco 1801 with c180x-advipservicesk9-mz.124-4.XC.bin IOS. It has BRI with outgoing as well as incoming dialers configured. Show isdn active shows hell lof of incoming calls though on the HUB router there are no active calls.
R1 # sh isdn act
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
In xx0709xxx 0510 698
In xx0709xxx 0510 664
In xx0709xxx 0510 625
In xx0709xxx 0510 622
In xx0709xxx 0510 615
In xx0709xxx 0510 603
In xx0709xxx 0510 594
In xx0709xxx 0510 591
In xx0709xxx 0510 588
In xx0709xxx 0510 586
In xx0709xxx 0510 582
In xx0709xxx 0510 580
In xx0709xxx 0510 569
In xx0709xxx 0510 555
In xx0709xxx 0510 552
In xx0709xxx 0510 546
In xx0709xxx 0510 530
In xx0709xxx 0510 488
In xx0709xxx 0510 484
In xx0709xxx 0510 481
In xx0709xxx 0510 478
In xx0709xxx 0510 474
In xx0709xxx 0510 468
In xx0709xxx 0510 454
In xx0709xxx 0510 451
In xx0709xxx 0510 445
In xx0709xxx 0510 441
In xx0709xxx 0510 435
In xx0709xxx 0510 420
In xx0709xxx 0510 417
In xx0709xxx 0510 411
In xx0709xxx 0510 365
In xx0709xxx 0510 322
In xx0709xxx 0510 319
In xx0709xxx 0510 313
In xx0709xxx 0510 301
In xx0709xxx 0510 287
In xx0709xxx 0510 286
In xx0709xxx 0510 284
In xx0709xxx 0510 282
In xx0709xxx 0510 281
In xx0709xxx 0510 277
In xx0709xxx 0510 275
In xx0709xxx 0510 265
In xx0709xxx 0510 254
In xx0709xxx 0510 251
In xx0709xxx 0510 245
In xx0709xxx 0510 230
In xx0709xxx 0510 227
In xx0709xxx 0510 221
In xx0709xxx 0510 201
In xx0709xxx 0510 198
In xx0709xxx 0510 192
In xx0709xxx 0510 190
In xx0709xxx 0510 186
In xx0709xxx 0510 183
In xx0709xxx 0510 180
In xx0709xxx 0510 177
In xx0709xxx 0510 175
In xx0709xxx 0510 172
In xx0709xxx 0510 166
In xx0709xxx 0510 151
In xx0709xxx 0510 148
In xx0709xxx 0510 142
In xx0709xxx 0510 139
In xx0709xxx 0510 133
In xx0709xxx 0510 117
In xx0709xxx 0510 114
In xx0709xxx 0510 108
In xx0709xxx 0510 1
These calls go on increasing even if I shut the BRI port and dialer interfaces. Is there anything with IOS or ISDN tweak needs ?
Santosh
Solved! Go to Solution.
12-07-2012 01:47 AM
Update IOS.
12-07-2012 01:47 AM
Update IOS.
