ISDN Connection Issue
rfalconer.sffcu
Level 3
Level 3
I'm having issues making a connection with my backup ISDN line. I'm enclosing a couple of show commands. I think the bold text might be the issue since I don't see that on any other devices that are working correctly.
Does that indicate an issue with the carrier?
xxx#sh controller bri
BRI unit 4:BRI unit 4 with U interface:
Layer 1 internal state is ACTIVATED
FPGA version = V6
FPGA create  = 09/02/18 24
Layer 1 U interface is ACTIVATED.
    External S/T is DEACTIVATED - Requesting Timing
ISDN Line Information:
    Last C/I from ISDN transceiver:
        AI:Activation Indication
    Last C/I to ISDN transceiver:
    Last C/I from ISDN S bus transceiver:
        TIM:Timing Required
    Last C/I to ISDN S bus transceiver:
        DR:Deactivation Request
    Current EOC commands:
        RTN - Return to normal
    Received overhead bits:  AIB=1, UOA=1, FEBE=1, DEA=1, ACT=1
    Errors:  Receive [NEBE]=0, Transmit [FEBE]=0
xxx#sh isdn status
Global ISDN Switchtype = basic-ni
ISDN BRI0/1/0 interface
        dsl 4, interface ISDN Switchtype = basic-ni
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 104, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
        TEI 104, ces = 1, state = 6(not initialized)
            spid1 configured, spid1 sent, spid1 NOT valid
        TEI Not Assigned, ces = 2, state = 1(terminal down)
            spid2 configured, spid2 NOT sent, spid2 NOT valid
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 4 CCBs = 0
    The Free Channel Mask:  0x80000003
    Total Allocated ISDN CCBs = 0
acampbell
Robert,
on your show isdn status note:-
Have a look at these links you probably have a configuration issue
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a0080094b78.shtml
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a0080093c44.shtml?referring_site=bodynav#intro
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Alex,
I did see that message as well.
I've verified the spids are valid (according to our records) and in the correct format. I've also removed them and re-entered them, as well as shut/no shut and clear int bri.
Robert,
Have look for your spid format in this link
http://www.ahk.com/spids.html
Alex.
