ISDN Error code 0x82E2 on PRI
phil_carter
I've set up an ISDN line between a PRI on a 3845 running IOS c3845-ipbase-mz.124-3g.bin, and a BRI on 2811 running IOS c2800nm-advipservicesk9-mz.124-8d.bin. When testing (or pinging across) the ISDN from the 3845 the ISDN line comes up for a second and then drops each time. The following error code is seen:
Cause i = 0x82E2 - Message not compatible with call state or not implemented
I found the following bug code for a similar IOS release (on the 3845), but not sure if this covers my problem:
CSCsi14053
Symptoms: When a gateway responds to a request for information (for example, "CC_INFO_REQ:Ux_InfoReq(nlcb)") from a service provider with an information message for incoming calls, the service provider releases the call with a message similar to the following one:
Q931: RX <- RELEASE pd = 8 callref = 0x00B2
Conditions: This symptom is observed when a Cisco platform that runs Cisco IOS Release 12.4(9)T2 or Release 12.4(11)T1 dials into a third-party vendor switch via a PRI.
Can anyone advise why the ISDN line drops continually every second and doesn't remain up? Interestingly, if you test the line with >1 calls it will stay up the default 120seconds before dropping....
Phil
11 Replies 11
paolo bevilacqua
One would need to see the full q931 trace to see in which context the message is thrown and who is to blame about.
Q931 debug info:
Jul 3 09:27:25: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0088
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Called Party Number i = 0x81, ''
Plan:ISDN, Type:Unknown
Jul 3 09:27:25: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8088
Jul 3 09:27:26: ISDN Se1/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x8088
Jul 3 09:27:26: %LINK-3-UPDOWN: Interface Serial1/0:30, changed state to up
Jul 3 09:27:26: %ISDN-6-CONNECT: Interface Serial1/0:30 is now connected to 011
62852587 N/A
Jul 3 09:27:26: ISDN Se1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0088
Jul 3 09:27:26: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8088
Cause i = 0x8090 - Normal call clearing
Jul 3 09:27:26: %LINK-3-UPDOWN: Interface Serial1/0:30, changed state to down
Jul 3 09:27:26: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x0088
Jul 3 09:27:26: ISDN Se1/0:15 Q931: RX <- STATUS pd = 8 callref = 0x8088
nted
Call State i = 0x0C
Jul 3 09:27:26: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8088
Jul 3 09:27:27: ISDN Se1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0
x1, Called num
you are receiving a a disconnect:
That is unrelated with the status messages, that comes after and is likely only a cosmetic issue.
You should look at the PPP debugs of the other router to see why it is disconnecting.
It looks as though it closes as a normal call, but it only stays up for a split second each time.... it should stay up for the default period. Logs from the other end (2811):
Jul 3 10:26:59: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Standard = CCITT
Channel ID i = 0x89
Calling Party Number i = 0x00A3, N/A
Plan:Unknown, Type:Unknown
Jul 3 10:26:59: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to up
Jul 3 10:26:59: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to N/A N
/A
Jul 3 10:26:59: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Jul 3 10:26:59: BR0/1/0:1 PPP: Using dialer call direction
Jul 3 10:26:59: BR0/1/0:1 PPP: Treating connection as a callin
Jul 3 10:26:59: BR0/1/0:1 PPP: Session handle[A0000710] Session id[963]
Jul 3 10:26:59: BR0/1/0:1 PPP: Phase is ESTABLISHING, Passive Open
Jul 3 10:26:59: BR0/1/0:1 LCP: State is Listen
Jul 3 10:26:59: ISDN BR0/1/0 Q931: TX -> CONNECT pd = 8 callref = 0x81
Jul 3 10:26:59: ISDN BR0/1/0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x01
Jul 3 10:26:59: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x81
Jul 3 10:26:59: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x01
Jul 3 10:26:59: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to down
Jul 3 10:26:59: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
Jul 3 10:26:59: BR0/1/0:1 LCP: State is Closed
Jul 3 10:26:59: BR0/1/0:1 PPP: Phase is DOWN
still check your ppp authentication debugs ,
Jul 3 12:46:59: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Standard = CCITT
Channel ID i = 0x89
Jul 3 12:46:59: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to up
Jul 3 12:46:59: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to N/A N
/A
Jul 3 12:46:59: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Jul 3 12:46:59: BR0/1/0:1 PPP: Using dialer call direction
Jul 3 12:46:59: BR0/1/0:1 PPP: Treating connection as a callin
Jul 3 12:46:59: BR0/1/0:1 PPP: Session handle[72000728] Session id[987]
Jul 3 12:46:59: BR0/1/0:1 PPP: Phase is ESTABLISHING, Passive Open
Jul 3 12:46:59: BR0/1/0:1 LCP: State is Listen
Jul 3 12:46:59: ISDN BR0/1/0 Q931: TX -> CONNECT pd = 8 callref = 0x81
Jul 3 12:46:59: ISDN BR0/1/0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x01
Jul 3 12:46:59: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x81
Jul 3 12:47:00: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x01
Jul 3 12:47:00: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to down
LCP doesn't appear to OPEN nor does CHAP authentication seem to take place. Usernames are present on both routers and both have ppp encapsulation configured. Your help is appreciated....
Hi, as mentioned before, you need "debug ppp negotiation" and "debug ppp authentication" taken on the router that is disconnecting.
Debug ppp authentication & debug ppp negotiation logs:
Dialling router:
Jul 10 15:42:32: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to up
Jul 10 15:42:32: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to N/A
Jul 10 15:42:32: BR0/1/0:1 PPP: Using dialer call direction
Jul 10 15:42:32: BR0/1/0:1 PPP: Treating connection as a callout
Jul 10 15:42:32: BR0/1/0:1 PPP: Session handle[A8000735] Session id[1000]
Jul 10 15:42:32: BR0/1/0:1 PPP: Phase is ESTABLISHING, Active Open
Jul 10 15:42:32: BR0/1/0:1 PPP: Authorization NOT required
Jul 10 15:42:32: BR0/1/0:1 LCP: O CONFREQ [Closed] id 111 len 15
Jul 10 15:42:32: BR0/1/0:1 LCP: AuthProto CHAP (0x0305C22305)
Jul 10 15:42:32: BR0/1/0:1 LCP: MagicNumber 0x824CE0F5 (0x0506824CE0F5)
Jul 10 15:42:32: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to down
Jul 10 15:42:32: BR0/1/0:1 PPP: Sending Acct Event[Down] id[1794]
Jul 10 15:42:32: BR0/1/0:1 LCP: State is Closed
Jul 10 15:42:32: BR0/1/0:1 PPP: Phase is DOWN
Jul 10 15:42:36: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to up
Jul 10 15:42:36: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to N/A
Jul 10 15:42:36: BR0/1/0:1 PPP: Using dialer call direction
Jul 10 15:42:36: BR0/1/0:1 PPP: Treating connection as a callout
Jul 10 15:42:36: BR0/1/0:1 PPP: Session handle[51000736] Session id[1001]
Jul 10 15:42:36: BR0/1/0:1 PPP: Phase is ESTABLISHING, Active Open
Jul 10 15:42:36: BR0/1/0:1 PPP: Authorization NOT required
Jul 10 15:42:36: BR0/1/0:1 LCP: O CONFREQ [Closed] id 112 len 15
Jul 10 15:42:36: BR0/1/0:1 LCP: AuthProto CHAP (0x0305C22305)
Jul 10 15:42:36: BR0/1/0:1 LCP: MagicNumber 0x824CF092 (0x0506824CF092)
Jul 10 15:42:36: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to down
Jul 10 15:42:36: BR0/1/0:1 PPP: Sending Acct Event[Down] id[1795]
Jul 10 15:42:36: BR0/1/0:1 LCP: State is Closed
Jul 10 15:42:36: BR0/1/0:1 PPP: Phase is DOWN
Remote router logs:
Jul 10 15:43:31: %LINK-3-UPDOWN: Interface Serial1/0:0, changed state to up
Jul 10 15:43:31: %ISDN-6-CONNECT: Interface Serial1/0:0 is now connected to N/A
Jul 10 15:43:31: Se1/0:0 PPP: Using dialer call direction
Jul 10 15:43:31: Se1/0:0 PPP: Treating connection as a callin
Jul 10 15:43:31: Se1/0:0 PPP: Session handle[2E000060] Session id[65]
Jul 10 15:43:31: Se1/0:0 PPP: Phase is ESTABLISHING, Passive Open
Jul 10 15:43:31: Se1/0:0 LCP: State is Listen
Jul 10 15:43:31: %LINK-3-UPDOWN: Interface Serial1/0:0, changed state to down
Jul 10 15:43:31: Se1/0:0 LCP: State is Closed
Jul 10 15:43:31: Se1/0:0 PPP: Phase is DOWN
Jul 10 15:43:35: %LINK-3-UPDOWN: Interface Serial1/0:0, changed state to up
Jul 10 15:43:35: %ISDN-6-CONNECT: Interface Serial1/0:0 is now connected to N/A
Jul 10 15:43:35: Se1/0:0 PPP: Using dialer call direction
Jul 10 15:43:35: Se1/0:0 PPP: Treating connection as a callin
Jul 10 15:43:35: Se1/0:0 PPP: Session handle[2000061] Session id[66]
Jul 10 15:43:35: Se1/0:0 PPP: Phase is ESTABLISHING, Passive Open
Jul 10 15:43:35: Se1/0:0 LCP: State is Listen
Jul 10 15:43:35: %LINK-3-UPDOWN: Interface Serial1/0:0, changed state to down
Jul 10 15:43:35: Se1/0:0 LCP: State is Closed
Jul 10 15:43:35: Se1/0:0 PPP: Phase is DOWN
rgds,
Phil
Hi, is the router with se1/0 working for other sites ? Which exact HW it has ?
Reason, it doesn't appear to receive any packet from the BRI routr, nor it sends any, that is very strange.
The dialling router has 2 bri's for 2 different remote sites (each on a pri), and both are seeing them same result. The router hardware is:
LEI_UTN_2811_01#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 1
RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 25-Jul-07 17:05 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
LEI_UTN_2811_01 uptime is 9 weeks, 6 days, 59 minutes
System returned to ROM by Reload Command
System restarted at 15:44:01 BST Fri May 2 2008
System image file is "flash:/c2800nm-advipservicesk9-mz.124-8d.bin"
A summary of U.S. laws governing Cisco cryptographic products may be fou
export@cisco.com.
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FCZ121173TB
2 FastEthernet interfaces
2 ISDN Basic Rate interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
It dials 2 remote routers, both 3845's running the same IOS:
SLH_UTN_3845_01#sh ver
Cisco IOS Software, 3800 Software (C3845-IPBASE-M), Version 12.4(3g), RELEASE S
FTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 06-Nov-06 05:34 by alnguyen
SLH_UTN_3845_01 uptime is 9 weeks, 1 day, 2 hours, 50 minutes
System restarted at 13:58:25 BST Wed May 7 2008
System image file is "flash:c3845-ipbase-mz.124-3g.bin"
Cisco 3845 (revision 1.0) with 223232K/38912K bytes of memory.
Processor board ID FCZ1121718R
2 Gigabit Ethernet interfaces
62 Serial interfaces
2 Channelized E1/PRI ports
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
I upgraded one of the 3845's to a new IOS (c3845-ipbase-mz.124-19b.bin) as the bug I mentioned does list 124-3g as affected, but the same thing happens when dialling.
rgds
Phil
Answer to your question about the remote router with Se1/0 dialling other sites - no. The remote router doesn't dial out to any site, it is only used to dial in via the single router.
