Isdn invoked with no apparently reason
maghisi-2007
Isdn backup layer 2 is constantly invoked with no reason for me as per local PTT main line is working perfectly.
By activating debug dialer events and debug isdn events, I can't get relevant informations.
I attached sh ver/sh run/debug results
Oct 12 12:37:09: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 70 changed to down
Oct 12 12:52:57: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 71 changed to up
Oct 12 12:53:09: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 71 changed to down
13 Replies 13
paolo bevilacqua
That is normal, configure "isdn tei-negotiation preserve" so the tei will not be negotiated every time L2 goes up.
I'm trying, thanks
You are welcome, please remember to rate useful posts with the scrollbox below.
Oct 13 14:12:57: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 83 changed to up
Oct 13 14:13:09: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 83 changed to down
I implemented the isdn command suggested above but I can see isdn layer 2 is still invoked even if the main circuit never got problems today
Check with "debug isdn q931" and "term mon" if there is any call associated with the activation.
debug isdn error is ON.
debug isdn q921 is ON. (filter is OFF)
debug isdn q931 is ON. (filter is OFF)
sh log
Oct 14 03:00:56: ISDN BR0/1/0 Q921: L2_EstablishDataLink: sending SABME
Oct 14 03:00:56: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=83
Oct 14 03:00:57: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=83
Oct 14 03:00:57: ISDN BR0/1/0 Q921: User RX <- UAf sapi=0 tei=83
Oct 14 03:00:57: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 83 changed to up
Oct 14 03:01:07: ISDN BR0/1/0 Q921: User TX -> RRp sapi=0 tei=83 nr=0
Oct 14 03:01:07: ISDN BR0/1/0 Q921: User RX <- RRf sapi=0 tei=83 nr=0
Oct 14 03:01:10: ISDN BR0/1/0 Q921: User RX <- DISCp sapi=0 tei=83
Oct 14 03:01:10: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 83 changed to down
Oct 14 03:01:10: ISDN BR0/1/0 Q921: User TX -> UAf sapi=0 tei=83
Oct 14 03:01:10: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Oct 14 03:01:20: ISDN BR0/1/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Oct 14 03:16:56: ISDN BR0/1/0 Q921: L2_EstablishDataLink: sending SABME
Oct 14 03:16:56: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=83
Oct 14 03:16:57: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=83
Oct 14 03:16:57: ISDN BR0/1/0 Q921: User RX <- UAf sapi=0 tei=83
Oct 14 03:16:57: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 83 changed to up
Oct 14 03:17:07: ISDN BR0/1/0 Q921: User TX -> RRp sapi=0 tei=83 nr=0
Oct 14 03:17:07: ISDN BR0/1/0 Q921: User RX <- RRf sapi=0 tei=83 nr=0
Oct 14 03:17:10: ISDN BR0/1/0 Q921: User RX <- DISCp sapi=0 tei=83
Oct 14 03:17:10: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 83 changed to down
Oct 14 03:17:10: ISDN BR0/1/0 Q921: User TX -> UAf sapi=0 tei=83
Oct 14 03:17:10: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Oct 14 03:17:20: ISDN BR0/1/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Oct 14 07:16:56: ISDN BR0/1/0 Q921: L2_EstablishDataLink: sending SABME
Oct 14 07:16:56: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=83
Oct 14 07:16:57: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=83
Oct 14 07:16:57: ISDN BR0/1/0 Q921: User RX <- UAf sapi=0 tei=83
Oct 14 07:16:57: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 83 changed to up
Oct 14 07:17:07: ISDN BR0/1/0 Q921: User TX -> RRp sapi=0 tei=83 nr=0
Oct 14 07:17:07: ISDN BR0/1/0 Q921: User RX <- RRf sapi=0 tei=83 nr=0
Oct 14 07:17:10: ISDN BR0/1/0 Q921: User RX <- DISCp sapi=0 tei=83
Oct 14 07:17:10: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 83 changed to down
Oct 14 07:17:10: ISDN BR0/1/0 Q921: User TX -> UAf sapi=0 tei=83
Oct 14 07:17:10: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Oct 14 07:17:20: ISDN BR0/1/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Oct 14 07:32:56: ISDN BR0/1/0 Q921: L2_EstablishDataLink: sending SABME
Oct 14 07:32:56: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=83
Oct 14 07:32:57: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=83
Oct 14 07:32:57: ISDN BR0/1/0 Q921: User RX <- UAf sapi=0 tei=83
Oct 14 07:32:57: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 83 changed to up
Oct 14 07:33:07: ISDN BR0/1/0 Q921: User TX -> RRp sapi=0 tei=83 nr=0
Oct 14 07:33:07: ISDN BR0/1/0 Q921: User RX <- RRf sapi=0 tei=83 nr=0
Oct 14 07:33:10: ISDN BR0/1/0 Q921: User RX <- DISCp sapi=0 tei=83
Oct 14 07:33:10: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 83 changed to down
Oct 14 07:33:10: ISDN BR0/1/0 Q921: User TX -> UAf sapi=0 tei=83
Oct 14 07:33:10: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Oct 14 07:33:20: ISDN BR0/1/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
You could enable debug bri to see if L1 activation comes from router or network.
Anyway, there are no unwanted calls and that is what matters, you can ignore the activations.
Just to try I activate anyway debug bri:
Oct 14 11:32:56: BRI0/1/0: In state F3, Received code Activate request downstream, Info 2 received
Oct 14 11:32:56: BRI0/1/0 : changing state to F6
Oct 14 11:32:56: BRI0/1/0: In state F6, Received code Activation Indication with Priority to 8, Info 4 received
Oct 14 11:32:56: BRI0/1/0 : Sending PH-Activate to the layer 2
Oct 14 11:32:56: BRI0/1/0 : changing state to F7
Oct 14 11:32:56: dchan tx fifo flush, actual_time = 0
Oct 14 11:32:56: BRI0/1/0 : stop and reset timer t3
Oct 14 11:32:56: BRI0/1/0: In state F7, Transmitting code Activation Request, set Priority to 8
Oct 14 11:32:56: BRI0/1/0 : Sending MPH-ERROR Indication reporting recovery from error to layer2
Oct 14 11:32:56: dchan tx start
Oct 14 11:32:56: dchan tx intr
Oct 14 11:32:57: dchan tx start
Oct 14 11:32:57: dchan tx intr
Oct 14 11:32:57: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 83 changed to up
Oct 14 11:33:07: dchan tx start
Oct 14 11:33:07: dchan tx intr
Oct 14 11:33:10: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 83 changed to down
Oct 14 11:33:10: dchan tx start
Oct 14 11:33:10: dchan tx intr
Oct 14 11:33:20: BRI0/1/0: In state F7, Received code Activate request downstream, Info 2 received
Oct 14 11:33:20: dchan tx fifo flush, actual_time = 0
Oct 14 11:33:20: BRI0/1/0 : changing state to F6
Oct 14 11:33:20: BRI0/1/0 : Sending MPH-ERROR Indication reporting error to layer2
Oct 14 11:33:20: BRI0/1/0: In state F6, Received code unknown code
Oct 14 11:33:20: BRI0/1/0 : stop and reset timer t3
Oct 14 11:33:20: BRI0/1/0 : changing state to F3
Oct 14 11:33:20: BRI0/1/0 : Starting layer 1 T4
Oct 14 11:33:21: BRI0/1/0 : T4 expired
Oct 14 11:33:21: BRI0/1/0 : Sending PH-DEACTIVATE to layer2
Oct 14 11:33:21: BRI0/1/0 : changing state to F3BRI: disable channel B1
BRI: disable channel B2
Oct 14 11:33:21: BRI0/1/0: In state F3, Transmitting code Deactivate indication upstream
Oct 14 11:33:21: BRI0/1/0: In state F3, Received code Deactivate indication downstream
Oct 14 11:33:21: BRI0/1/0 : do nothingBRI: disable channel B1
Oct 14 11:48:56: BRI0/1/0: In state F3, Received code Activate request downstream, Info 2 received
Oct 14 11:48:56: BRI0/1/0 : changing state to F6
Oct 14 11:48:56: BRI0/1/0: In state F6, Received code Activation Indication with Priority to 8, Info 4 received
Oct 14 11:48:56: BRI0/1/0 : Sending PH-Activate to the layer 2
Oct 14 11:48:56: BRI0/1/0 : changing state to F7
Oct 14 11:48:56: dchan tx fifo flush, actual_time = 0
Oct 14 11:48:56: BRI0/1/0 : stop and reset timer t3
Oct 14 11:48:56: BRI0/1/0: In state F7, Transmitting code Activation Request, set Priority to 8
Oct 14 11:48:56: BRI0/1/0 : Sending MPH-ERROR Indication reporting recovery from error to layer2
Oct 14 11:48:56: dchan tx start
Oct 14 11:48:56: dchan tx intr
Oct 14 11:48:57: dchan tx start
Oct 14 11:48:57: dchan tx intr
Oct 14 11:48:57: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 83 changed to up
Oct 14 11:49:07: dchan tx start
Oct 14 11:49:07: dchan tx intr
Oct 14 11:49:10: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 83 changed to down
Oct 14 11:49:10: dchan tx start
Oct 14 11:49:10: dchan tx intr
Oct 14 11:49:20: BRI0/1/0: In state F7, Received code Activate request downstream, Info 2 received
Oct 14 11:49:20: dchan tx fifo flush, actual_time = 0
Oct 14 11:49:20: BRI0/1/0 : changing state to F6
Oct 14 11:49:20: BRI0/1/0 : Sending MPH-ERROR Indication reporting error to layer2
Oct 14 11:49:20: BRI0/1/0: In state F6, Received code unknown code
Oct 14 11:49:20: BRI0/1/0 : stop and reset timer t3
Oct 14 11:49:20: BRI0/1/0 : changing state to F3
Oct 14 11:49:20: BRI0/1/0 : Starting layer 1 T4
Oct 14 11:49:21: BRI0/1/0 : T4 expired
Oct 14 11:49:21: BRI0/1/0 : Sending PH-DEACTIVATE to layer2
Oct 14 11:49:21: BRI0/1/0 : changing state to F3BRI: disable channel B1
Activation comes from network and there is nothing you can do about.
Please review your use of the rating system, because my info is 100% complete and correct, not fairly rated with "3".
Excuse me for the rating system. I didn't want to be unfair. I do not often use cisco forum and I was thinking that I should give you the best rating just at the end of the conversation. Now I know I can give you the best rating at any time. When you write that activation comes from the network do you mean that is coming from the customer Lan?
No, it comes from telco with no apparent reason, as mentioned you cannot do anything about, and it's not harmful in any manner.
Ok thanks for all your efforts. Excuse me once again for mine previous errors. For me this conversation has been successfully closed
You are welcome, thank you for the nice rating and good luck.
