ISDN PRI
drnteam
Did any one face the above error when configuring the PRI.
AEDICR08(config-controller)#pri-group timeslots 1-31
% Not enough DSP resources available to configure pri-group on controller E1 0/0
/0
% The remaining dsp resources are enough for 0 time slots.
% For current codec complexity, 2 extra dsp(s) are required to create this voice
port.
Also i am not able to configure the card type. My router type is 2800.
Eldo
paolo bevilacqua
The vwic card that you're using is meant for voice mainly and need DSP resource when configuring PRI. Are you configuring the router for voice applications ?
Card type is needed only when you have vwic2, you have vwic.
