ISDN problem
manoj.jain
Hi...
Can any one help me , i m facing one problem , im using ISDN line & leased line .Everything going smooth when using leased line (All aplication and VOIP phone working properly.)but when i switch over to ISDN line (For backup purpose) connectivity very slow and VOIP phone not working properly. Is that due to routing table problem?
Plz help me
Thanx
spremkumar
Level 9
Level 9
Hi Manoj
do revert back how you want to have your traffic routed ..
If you are going to use the GRE tunnel for forwarding the traffic to your remote location then make sure that your default route pointing towards the tunnel 0.
To reach the tunnel destination via serial and bri create static routes one with admin distance via BRI the other one without any admin distance via serial.
If you still have ips to be routed then point them via serial with a backup route pointing thme via bri.
ip route 0.0.0.0 0.0.0.0 Tunnel10
ip route 203.201.255.97 255.255.255.255 Serial 0/0
ip route 203.201.255.97 255.255.255.255 BRI1/0 100
regds
smothuku
Level 7
Level 7
Hi ,
In config file I observed that you have give same subent to leased line and isdn line.
i.e
interface Serial0/0
description *****LL to xx 2MB ******
bandwidth 128
ip address 203.124.194.146 255.255.255.252
interface BRI1/0
encapsulation ppp
Configure different subent for bri1/0 and chec the issue.
satish
Hi Satish
Since hes using backup interface command under serial interface having the same ip address wont have any effect on the routing table.
The bri interface will be considered shut till the serial is up once the serial goes down then only the bri interface will be activated.
I have seen this kinda config in working environments also better to have the same ip on both serial and bri to have single end to end tunnel created between the peers.
Also if we want to have ipsec vpn then this kinda config comes handy...
regds
