Chat-script issue
netadmincsm
Level 2
Level 2
Hi all
I have Cisco 891 with integrated Async (V.92) interface.  I do not use modemcap yet.  I'm only running chat-script for AT configuration.  I used this kind of setup on 831 with External USRobotics for 5 years on houndred sites.
Here's what I'm able to do with the 891
- Boot up the router
- Access AT command prompt using telnet [Loopback IP] on 2001 port
- Type an ATZ command
- Disconnect from AT command prompt
- Trigger the Dialing process
     - Chat-script : ABORT ERROR "" "ATDT \T" TIMEOUT 60 CONNECT \c
     - Async configuration :
          ip address negotiated
           encapsulation ppp
           dialer in-band
           dialer idle-timeout 60
           dialer wait-for-carrier-time 10
           dialer string XXXXXXX modem-script dialout
           dialer watch-group 8
           async dynamic address
           async dynamic routing
           async mode dedicated
           no keepalive
           ppp pap sent-username XXXXXXXX password XXXXXXX
     - Line 1 configuration :
          line 1
           exec-timeout 0 0
           modem InOut
           stopbits 1
           speed 115200
           flowcontrol hardware
- I'm now connected to my ISP.
     - Debug "ppp authe", "ppp nego", "chat line 1"
Jun 15 18:17:05: CHAT1: Attempting async line dialer script
Jun 15 18:17:05: CHAT1: Dialing using Modem script: dialout & System script: none
Jun 15 18:17:05: CHAT1: process started
Jun 15 18:17:05: CHAT1: Asserting DTR
Jun 15 18:17:05: CHAT1: Chat script dialout started
Jun 15 18:17:05: CHAT1: Sending string: ATDT \T<XXXXXXXXXX>
Jun 15 18:17:05: CHAT1: Expecting string: CONNECT
Jun 15 18:17:05: CHAT1: Input mismatch expecting: CONNECT :: ATDT XXXXXXXXXX\015
Jun 15 18:17:27: CHAT1: Input match for: CONNECT:: CONNECT
Jun 15 18:17:27: CHAT1: Completed match for expect: CONNECT
Jun 15 18:17:27: CHAT1: Sending string: \c
Jun 15 18:17:27: CHAT1: Chat script dialout finished, status = Success
Jun 15 18:17:29: %LINK-3-UPDOWN: Interface Async1, changed state to up
Jun 15 18:17:29: As1 PPP: Sending cstate UP notification
Jun 15 18:17:29: As1 PPP: Processing CstateUp message
Jun 15 18:17:29: PPP: Alloc Context [86445068]
Jun 15 18:17:29: ppp2 PPP: Phase is ESTABLISHING
Jun 15 18:17:29: As1 PPP: Using dialer call direction
Jun 15 18:17:29: As1 PPP: Treating connection as a callout
Jun 15 18:17:29: As1 PPP: Session handle[69000002] Session id[2]
Jun 15 18:17:29: As1 LCP: Event[OPEN] State[Initial to Starting]
Jun 15 18:17:29: As1 PPP: No remote authentication for call-out
Jun 15 18:17:29: As1 LCP: O CONFREQ [Starting] id 1 len 20
Jun 15 18:17:29: As1 LCP:    ACCM 0x000A0000 (0x0206000A0000)
Jun 15 18:17:29: As1 LCP:    MagicNumber 0x0109C3A9 (0x05060109C3A9)
Jun 15 18:17:29: As1 LCP:    PFC (0x0702)
Jun 15 18:17:29: As1 LCP:    ACFC (0x0802)
Jun 15 18:17:29: As1 LCP: Event[UP] State[Starting to REQsent]
Jun 15 18:17:29: As1 LCP: I CONFREQ [REQsent] id 116 len 42
Jun 15 18:17:29: As1 LCP:    AuthProto PAP (0x0304C023)
Jun 15 18:17:29: As1 LCP:    MagicNumber 0x628C6AB3 (0x0506628C6AB3)
Jun 15 18:17:29: As1 LCP:    MRRU 1524 (0x110405F4)
Jun 15 18:17:29: As1 LCP:    EndpointDisc 1 QBCStackGrp (0x130E01514243537461636B477270)
Jun 15 18:17:29: As1 LCP: O CONFREJ [REQsent] id 116 len 8
Jun 15 18:17:29: As1 LCP: Event[Receive ConfReq-] State[REQsent to REQsent]
Jun 15 18:17:29: As1 LCP: I CONFACK [REQsent] id 1 len 20
Jun 15 18:17:29: As1 LCP: Event[Receive ConfAck] State[REQsent to ACKrcvd]
Jun 15 18:17:30: As1 LCP: I CONFREQ [ACKrcvd] id 117 len 38
Jun 15 18:17:30: As1 LCP:    ACCM 0x000A0000 (0x0206000A0000)
Jun 15 18:17:30: As1 LCP:    AuthProto PAP (0x0304C023)
Jun 15 18:17:30: As1 LCP:    MagicNumber 0x628C6AB3 (0x0506628C6AB3)
Jun 15 18:17:30: As1 LCP:    PFC (0x0702)
Jun 15 18:17:30: As1 LCP:    ACFC (0x0802)
Jun 15 18:17:30: As1 LCP:    EndpointDisc 1 QBCStackGrp (0x130E01514243537461636B477270)
Jun 15 18:17:30: As1 LCP: O CONFACK [ACKrcvd] id 117 len 38
Jun 15 18:17:30: As1 LCP: Event[Receive ConfReq+] State[ACKrcvd to Open]
Jun 15 18:17:30: As1 PPP: Phase is AUTHENTICATING, by the peer
Jun 15 18:17:30: As1 PAP: Using hostname from interface PAP
Jun 15 18:17:30: As1 PAP: Using password from interface PAP
Jun 15 18:17:30: As1 PAP: O AUTH-REQ id 1 len 34 from "XXXXXXXX"
Jun 15 18:17:30: As1 LCP: State is Open
Jun 15 18:17:30: As1 PAP: I AUTH-ACK id 1 len 5
Jun 15 18:17:30: As1 PPP: Phase is FORWARDING, Attempting Forward
Jun 15 18:17:30: As1 PPP: Phase is ESTABLISHING, Finish LCP
Jun 15 18:17:30: As1 PPP: Phase is UP
Jun 15 18:17:30: As1 IPCP: Protocol configured, start CP. state[Initial]
Jun 15 18:17:30: As1 IPCP: Event[OPEN] State[Initial to Starting]
Jun 15 18:17:30: As1 IPCP: O CONFREQ [Starting] id 1 len 10
Jun 15 18:17:30: As1 IPCP:    Address 0.0.0.0 (0x030600000000)
Jun 15 18:17:30: As1 IPCP: Event[UP] State[Starting to REQsent]
Jun 15 18:17:30: As1 IPCP: I CONFREQ [REQsent] id 239 len 16
Jun 15 18:17:30: As1 IPCP:    CompressType VJ 15 slots (0x0206002D0F00)
Jun 15 18:17:30: As1 IPCP:    Address 111.111.111.111 (0x0306CEAC99F2)
Jun 15 18:17:30: As1 IPCP: O CONFREJ [REQsent] id 239 len 10
Jun 15 18:17:30: As1 IPCP: Event[Receive ConfReq-] State[REQsent to REQsent]
Jun 15 18:17:30: As1 IPCP: I CONFREQ [REQsent] id 240 len 16
Jun 15 18:17:30: As1 IPCP: O CONFREJ [REQsent] id 240 len 10
Jun 15 18:17:30: As1 IPCP: I CONFNAK [REQsent] id 1 len 10
Jun 15 18:17:30: As1 IPCP:    Address 111.111.111.111 (0x0306CEAC9995)
Jun 15 18:17:30: As1 IPCP: O CONFREQ [REQsent] id 2 len 10
Jun 15 18:17:30: As1 IPCP: Event[Receive ConfNak/Rej] State[REQsent to REQsent]
Jun 15 18:17:30: As1 IPCP: I CONFREQ [REQsent] id 241 len 10
Jun 15 18:17:30: As1 IPCP: O CONFACK [REQsent] id 241 len 10
Jun 15 18:17:30: As1 IPCP: Event[Receive ConfReq+] State[REQsent to ACKsent]
Jun 15 18:17:30: As1 IPCP: I CONFACK [ACKsent] id 2 len 10
Jun 15 18:17:30: As1 IPCP: Event[Receive ConfAck] State[ACKsent to Open]
Jun 15 18:17:30: As1 IPCP: State is Open
Jun 15 18:17:30: As1 IPCP: Install negotiated IP interface address 111.111.111.111
Jun 15 18:17:30: As1 Added to neighbor route AVL tree: topoid 0, address 111.111.111.111
Jun 15 18:17:30: As1 IPCP: Install route to 111.111.111.111
Here's what I'm not able to do with the 891
If I try to add the ATZ I did manually into the chat-script I have the following :
     - Chat-script : ABORT ERROR "" "ATZ" OK "ATDT \T" TIMEOUT 60 CONNECT \c
           encapsulation ppp
           dialer in-band
           no keepalive
          line 1
           exec-timeout 0 0
           modem InOut
           stopbits 1
           speed 115200
- I'm not able to connect to my ISP.
Jun 15 18:56:04: CHAT1: Attempting async line dialer script
Jun 15 18:56:04: CHAT1: Dialing using Modem script: dialout & System script: none
Jun 15 18:56:04: CHAT1: process started
Jun 15 18:56:04: CHAT1: Asserting DTR
Jun 15 18:56:04: CHAT1: Chat script dialout started
Jun 15 18:56:04: CHAT1: Sending string: ATZ
Jun 15 18:56:04: CHAT1: Expecting string: OK
Jun 15 18:56:04: CHAT1: Input mismatch expecting: OK :: ATZ\015\015\012
Jun 15 18:56:04: CHAT1: Input match for: OK:: OK
Jun 15 18:56:04: CHAT1: Completed match for expect: OK
Jun 15 18:56:08: CHAT1: Sending string: ATDT \T<XXXXXXXXXX>
Jun 15 18:56:08: CHAT1: Expecting string: CONNECT
Jun 15 18:56:08: CHAT1: Input mismatch expecting: CONNECT :: AT+MR=1\015\015\012OK\015\012AT+DR=1\015\015\012OK\015\012AT\V4\015\015\012OK\015\012ATS0=1\015\015\012OK\015\012AT:U70,A700\015\015\012OK\015\012AT&D2\015\015\012OK\015\012ATE1\015\015\012OK\015\012ATDT XXXXXXXXXX\015\015\012+M
Jun 15 18:56:30: CHAT1: Input match for: CONNECT:: C
Jun 15 18:56:30: CHAT1: Input mismatch expecting: CONNECT :: R:V90\015\012\015\012+MRR:24000,50666\015\012\015\012+DR:V44 \015\012\015\012
Jun 15 18:56:30: CHAT1: Input match for: CONNECT:: CONNECT
Jun 15 18:56:30: CHAT1: Completed match for expect: CONNECT
Jun 15 18:56:30: CHAT1: Sending string: \c
Jun 15 18:56:30: CHAT1: Chat script dialout finished, status = Success
Jun 15 18:56:32: %LINK-3-UPDOWN: Interface Async1, changed state to up
Jun 15 18:56:32: As1 PPP: Sending cstate UP notification
Jun 15 18:56:32: As1 PPP: Processing CstateUp message
Jun 15 18:56:32: PPP: Alloc Context [860A26E8]
Jun 15 18:56:32: ppp2 PPP: Phase is ESTABLISHING
Jun 15 18:56:32: As1 PPP: Using dialer call direction
Jun 15 18:56:32: As1 PPP: Treating connection as a callout
Jun 15 18:56:32: As1 PPP: Session handle[D8000002] Session id[2]
Jun 15 18:56:32: As1 LCP: Event[OPEN] State[Initial to Starting]
Jun 15 18:56:32: As1 PPP: No remote authentication for call-out
Jun 15 18:56:32: As1 LCP: O CONFREQ [Starting] id 1 len 20
Jun 15 18:56:32: As1 LCP:    ACCM 0x000A0000 (0x0206000A0000)
Jun 15 18:56:32: As1 LCP:    MagicNumber 0x0103CB4C (0x05060103CB4C)
Jun 15 18:56:32: As1 LCP:    PFC (0x0702)
Jun 15 18:56:32: As1 LCP:    ACFC (0x0802)
Jun 15 18:56:32: As1 LCP: Event[UP] State[Starting to REQsent]
Jun 15 18:56:34: As1 LCP: O CONFREQ [REQsent] id 2 len 20
Jun 15 18:56:34: As1 LCP:    ACCM 0x000A0000 (0x0206000A0000)
Jun 15 18:56:34: As1 LCP:    MagicNumber 0x0103CB4C (0x05060103CB4C)
Jun 15 18:56:34: As1 LCP:    PFC (0x0702)
Jun 15 18:56:34: As1 LCP:    ACFC (0x0802)
Jun 15 18:56:34: As1 LCP: Event[Timeout+] State[REQsent to REQsent]
Jun 15 18:56:36: As1 LCP: O CONFREQ [REQsent] id 3 len 20
Jun 15 18:56:36: As1 LCP:    ACCM 0x000A0000 (0x0206000A0000)
Jun 15 18:56:36: As1 LCP:    MagicNumber 0x0103CB4C (0x05060103CB4C)
Jun 15 18:56:36: As1 LCP:    PFC (0x0702)
Jun 15 18:56:36: As1 LCP:    ACFC (0x0802)
Jun 15 18:56:36: As1 LCP: Event[Timeout+] State[REQsent to REQsent]
Jun 15 18:56:38: As1 LCP: O CONFREQ [REQsent] id 4 len 20
Jun 15 18:56:38: As1 LCP:    ACCM 0x000A0000 (0x0206000A0000)
Jun 15 18:56:38: As1 LCP:    MagicNumber 0x0103CB4C (0x05060103CB4C)
Jun 15 18:56:38: As1 LCP:    PFC (0x0702)
Jun 15 18:56:38: As1 LCP:    ACFC (0x0802)
Jun 15 18:56:38: As1 LCP: Event[Timeout+] State[REQsent to REQsent]
Jun 15 18:56:40: As1 LCP: O CONFREQ [REQsent] id 5 len 20
Jun 15 18:56:40: As1 LCP:    ACCM 0x000A0000 (0x0206000A0000)
Jun 15 18:56:40: As1 LCP:    MagicNumber 0x0103CB4C (0x05060103CB4C)
Jun 15 18:56:40: As1 LCP:    PFC (0x0702)
Jun 15 18:56:40: As1 LCP:    ACFC (0x0802)
Jun 15 18:56:40: As1 LCP: Event[Timeout+] State[REQsent to REQsent]
Jun 15 18:56:42: As1 LCP: O CONFREQ [REQsent] id 6 len 20
Jun 15 18:56:42: As1 LCP:    ACCM 0x000A0000 (0x0206000A0000)
Jun 15 18:56:42: As1 LCP:    MagicNumber 0x0103CB4C (0x05060103CB4C)
Jun 15 18:56:42: As1 LCP:    PFC (0x0702)
Jun 15 18:56:42: As1 LCP:    ACFC (0x0802)
Jun 15 18:56:42: As1 LCP: Event[Timeout+] State[REQsent to REQsent]
Jun 15 18:56:42: As1 LCP: I CONFREQ [REQsent] id 6 len 20
Jun 15 18:56:42: As1 LCP: Loopback seen, Magic number not Acked
Jun 15 18:56:42: As1 LCP: O CONFNAK [REQsent] id 6 len 10
Jun 15 18:56:42: As1 LCP:    MagicNumber 0x0103F2A3 (0x05060103F2A3)
Jun 15 18:56:42: As1 LCP: Event[Receive ConfReq-] State[REQsent to REQsent]
Jun 15 18:56:42: As1 LCP: I CONFNAK [REQsent] id 6 len 10
Jun 15 18:56:42: As1 PPP: Line appears to be looped back
Jun 15 18:56:45: As1 LCP: O CONFREQ [REQsent] id 7 len 20
Jun 15 18:56:45: As1 LCP:    ACCM 0x000A0000 (0x0206000A0000)
Jun 15 18:56:45: As1 LCP:    MagicNumber 0x0103F2A8 (0x05060103F2A8)
Jun 15 18:56:45: As1 LCP:    PFC (0x0702)
Jun 15 18:56:45: As1 LCP:    ACFC (0x0802)
Jun 15 18:56:45: As1 LCP: Event[Timeout+] State[REQsent to REQsent]
Jun 15 18:56:45: %LINK-5-CHANGED: Interface Async1, changed state to reset
Jun 15 18:56:45: As1 PPP: Sending cstate DOWN notification
Jun 15 18:56:45: As1 PPP: Processing CstateDown message
Jun 15 18:56:45: As1 PPP DISC: Lower Layer disconnected
Jun 15 18:56:45: As1 PPP: Sending Acct Event[Down] id[E]
Jun 15 18:56:45: PPP: NET STOP send to AAA.
Jun 15 18:56:45: As1 LCP: O TERMREQ [REQsent] id 8 len 4
Jun 15 18:56:45: As1 LCP: Event[CLOSE] State[REQsent to Closing]
Jun 15 18:56:45: As1 PPP: Phase is TERMINATING
Jun 15 18:56:45: As1 LCP: Event[DOWN] State[Closing to Initial]
Jun 15 18:56:45: As1 PPP: Phase is DOWN
NOTE : If I try to use the Factory default option from a modemcap instead of ATZ with CHAT-SCRIPT I have the same issue
Why am I able to connect only when I use the ATZ manually ?
I'm confused 😐
Thanks for your help
paolo bevilacqua
Already asked in another thread, please avoid posting duplicates.
I know, I tried to delete the old post but it doesn't work.
We advanced in the issue.  We now have trouble with chat-script.
The post is different.
Sorry for the inconvenient.
It's  strange, somehow the chat script seems acting completely wrong.
