ISDN switch
haa33110
Hi, all!
Is there any Cisco product that can configure
as teleco's ISDN switch? I cannot sleep well because of this question. Please help me!
Thanks.
paolo bevilacqua
All cisco ISDN interface support network as well user side configuration.
Thanks for your hint.
Important infomations slipped my mind.
I have some Cisco 2500 routers and
Cisco 4500 routers with multiple BRI module.
I want to let this 4500 relay at my home labo.
Does learning ISDN deeply make this come true?
Because Cisco's ISDN interfaces can send and receive q.921 and 9.31 signaling messages.
Honestly speaking, I couldn't understand
what you meant. But I see it now.
User side ISDN interface cannot pass
any signal to the opposite end of the
line, if it also is User side ISDN
interface.
I shed tonight till morning so that
the golden slumber doesn't come back
to me tonight.
Hi, for network side you will need the interfaces that are named nt/te. The routers you have are too old and don't have that.
Thanks for the appreciation and good luck!
