ISR 1100 - NAT preventing backup WAN from working
David Birks
Good Afternoon,
We are trying to configure our Cisco router with a backup WAN but are having issues getting the NAT configured properly to allow traffic onto the backup connection. We have confirmed that the static route is automatically removed when the primary WAN does offline, however we are unable to
ping
the gateway on the secondary WAN. Removing the NAT entry for the primary WAN instantly allows traffic to flow over the secondary WAN, so it seems the issue is most likely with the NAT configuration itself.
Below is the current configuration of the router, any assistance on getting this resolved would be greatly appriecated.
Kind Regards,
David
version 17.9
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
platform hardware throughput crypto 50000
hostname BrewerySecurity
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone GMT 0 0
ip name-server 192.168.88.1 192.168.10.1 1.1.1.1
ip domain name BrewSec.local
ip dhcp excluded-address 172.16.0.0 172.16.0.99
ip dhcp excluded-address 172.16.0.201 172.16.0.255
ip dhcp pool BrewSec
network 172.16.0.0 255.255.255.0
default-router 172.16.0.1
dns-server 172.16.0.1
login on-success log
ipv6 unicast-routing
subscriber templating
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki trustpoint TP-self-signed-2012739551
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2012739551
revocation-check none
rsakeypair TP-self-signed-2012739551
crypto pki certificate chain SLA-TrustPoint
crypto pki certificate chain TP-self-signed-2012739551
license udi pid C1111-8P sn FCZ2712R201
memory free low-watermark processor 65797
diagnostic bootup level minimal
username admin privilege 15 secret 9 *******
redundancy
mode none
vlan internal allocation policy ascending
track 1 ip sla 1 state
interface GigabitEthernet0/0/0
ip address 192.168.88.5 255.255.255.0
ip nat outside
negotiation auto
interface GigabitEthernet0/0/1
ip address 192.168.10.5 255.255.255.0
ip nat outside
negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Vlan1
ip address 172.16.0.1 255.255.255.0
ip nat inside
ip http server
ip http authentication local
ip http secure-server
ip forward-protocol nd
ip dns server
ip nat inside source route-map NAT-WAN1 interface GigabitEthernet0/0/0 overload
ip nat inside source route-map NAT-WAN2 interface GigabitEthernet0/0/1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 192.168.88.1 track 1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/1 192.168.10.1 253
ip sla 1
icmp-echo 8.8.8.8 source-interface GigabitEthernet0/0/0
ip sla schedule 1 life forever start-time now
ip access-list extended 197
10 permit ip any any
route-map NAT-WAN1 permit 10
match ip address 197
set interface GigabitEthernet0/0/0
route-map NAT-WAN2 permit 10
set interface GigabitEthernet0/0/1
control-plane
line con 0
transport input none
stopbits 1
line vty 0
login
length 0
transport input ssh
line vty 1 4
login
transport input ssh
line vty 5 14
login
transport input ssh
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
end
Change the
route map
of NAT
Instead of
set interface
 Change it to
match interface
 And it will work
5 Replies 5
Change the
route map
of NAT
Instead of
set interface
 Change it to
match interface
 And it will work
I've looked at several example configurations and never noticed that little discrepancy. I made the changes and it starting working immediately. Thank you very much for the quick response.
You are so welcome
Have a nice weekend
MHM
Hello @David Birks @MHM Cisco World
Please note how you have your IPSLA configured at present could blackhole or at least cause network instability to your LAN/NAT traffic.
The reason being if  ISP1 incurs an outage upstream thus leaving its directly connected interface to your RTR in a up state, Then your rtr will then most probably begin to learn and
relearn 8.8.8.8
via ISP2 which will then no doubt cause your IPSLA to begin to flap.
The way to negate such an issue would be to apply some local policy-based routing so the IPSLA probes are not sourced from ISP1 physical interface if such a outage upstream is incurred to ISP1
Example:
access-list 101 permit icmp host 192.168.88.5 host 8.8.8.8 echo
route-map ipsla
match ip address 101
set ip next-hop 192.168.88.1
set interface Null0
ip local policy route-map ipsla
Kind Regards
Paul
