ISR 1113 right to use licence
Ron Reid
I have a ISR1113 with XE c1100-universalk9_ias.16.08.01.SPA.bin and I'm trying to activate the right to use licence with no joy. The Cisco configuration guide has no useful information on the licensing for this router and the right-to-use command documentation for other devices don't work for this router.
The license I'm trying to activate is the security
I have run the command "license right-to-use move securityk9", which executed. I have reloaded to router and when I run "show license right-to-use" I get the following results:
Index 2 Feature: securityk9
Period left: Life time
License Type: RightToUse
License State: Active, Not in Use, EULA accepted
License Count: Non-Counted
License Priority: Low
This doesn't seem to have done anything useful because I still can's use the crypto commands to create VPN's.
What am I doing wrong?
If Cisco have this documented somewhere they've hidden it astonishingly well.
Ron Reid
I have found the solution to this. The following command is also needed in the config to load the feature set:
In config mode add the command:
license boot level securityk9
exit config, copy run start and then reload
Ron Reid
yes you are correct.
The first command is just to accept the EULA
-> License State: Active, Not in Use, EULA accepted
the other is to activate the license after reboot
int the System Management Configuration Guide, Cisco IOS XE
you can find
Table 1  RTU License StatesLicense State Description
Active, In Use
EULA was accepted and the license is in use after device reboot.
Active, Not In Use
EULA was accepted and the switch is ready to use when the license is enabled.
Not Activated
EULA was not accepted.
