ISR 1118-8p
Kalin Hristov
Hello guys,
Does anyone have any info about this particular box? Despite the fact that it is "8p" model acording to Cisco website it has only 4 ports switch. Is this true "8p"model in terms of performance? What I mean is that I know 4p models are 50% less powerful then their 8p counterparts, what about this particular model, is it comes with 800MHz CPU or 1200MHz like 1111-8p?
marce1000
 - Several references to this model can be found in the datasheet :
           https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.html
         Look for 1118-8p , to observer specific properties for this model
 M.
Thanks for the reply. The info is a bit confusing, in this URL it is listed as 4 ports model:
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/guide-c07-740009.html
 Ref : https://gzhls.at/blob/ldb/9/8/c/6/7342f7ae724532435a5452f0e0c491da1c74.pdf
  The Cisco ISR C1100-8P series comes with 8-Gigabit Ethernet LAN ports, and two WAN ports, with options
for one LTE modem and one WLAN interface.
 M.
