ISR 2921 QOS Question
Damien Miller
I am wondering if anyone else has experienced the QOS issue I am facing right now.  We have a 200Mbps evpl circuit terminated by a 2921 on one end and a 3650 on the other.  The 3650 also has an outbound policy shaping to 200Mbps and this is working as expected and the line is utilized completely going 3650 to 2921.  Traffic traversing outbound from the 2921 towards the 3650 shapes to around 100Mbps.  The offered rate in the "sh policy-map interface gi0/2" as well as the drop rate is what has me stumped.  Any input would be appreciated.
policy-map PM-EVPL
 class class-default
  shape average 200000000
 Policy Map PM-EVPL
    Class class-default
      Average Rate Traffic Shaping
      cir 200000000 (bps)
This output was taken at 30 second intervals.
DR-2921#sh interfaces gi0/2
GigabitEthernet0/2 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is 88f0.319b.8002 (bia 88f0.319b.8002)
  Description: *Shaw EVPL to DC-3650*
  Internet address is 10.100.0.1/30
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 3/255, rxload 46/255
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 6d03h
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 196354
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/1986034 (size/max total/drops)
  30 second input rate 180698000 bits/sec, 17290 packets/sec
  30 second output rate 15590000 bits/sec, 9185 packets/sec
     2747558734 packets input, 101836841 bytes, 0 no buffer
     Received 58663 broadcasts (0 IP multicasts)
     0 watchdog, 58663 multicast, 0 pause input
     1420497942 packets output, 3759544350 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
DR-2921#sh policy-map interface gi0/2
 GigabitEthernet0/2
  Service-policy output: PM-EVPL
    Class-map: class-default (match-any)
      1420719666 packets, 167258939121 bytes
      30 second offered rate 6813000 bps, drop rate 30000 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/196354/0
      (pkts output/bytes output) 1420523314/167001133017
      shape (average) cir 200000000, bc 800000, be 800000
      target shape rate 200000000
DR-2921#
DR-2921#
     reliability 255/255, txload 19/255, rxload 17/255
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 196795
  Output queue: 0/1000/1986844 (size/max total/drops)
  30 second input rate 69052000 bits/sec, 9369 packets/sec
  30 second output rate 76032000 bits/sec, 9224 packets/sec
     2747786639 packets input, 217718107 bytes, 0 no buffer
     Received 58667 broadcasts (0 IP multicasts)
     0 watchdog, 58667 multicast, 0 pause input
     1420833292 packets output, 4211606272 bytes, 0 underruns
 GigabitEthernet0/2
      1421062171 packets, 167724231956 bytes
      30 second offered rate 81378000 bps, drop rate 116000 bps
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops) 0/196795/0
      (pkts output/bytes output) 1420865376/167465891262
DR-2921#
     reliability 255/255, txload 23/255, rxload 7/255
  30 second input rate 31339000 bits/sec, 6517 packets/sec
  30 second output rate 91763000 bits/sec, 8874 packets/sec
     2747941553 packets input, 264153037 bytes, 0 no buffer
     Received 58670 broadcasts (0 IP multicasts)
     0 watchdog, 58670 multicast, 0 pause input
     1421099106 packets output, 297835524 bytes, 0 underruns
 GigabitEthernet0/2
      1421336953 packets, 168119384984 bytes
      30 second offered rate 94283000 bps, drop rate 34000 bps
      Match: any
      Queueing
      (pkts output/bytes output) 1421140158/167861044290
DR-2921#
DR-2921#
     reliability 255/255, txload 24/255, rxload 7/255
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 198203
  Output queue: 0/1000/1988252 (size/max total/drops)
  30 second input rate 30559000 bits/sec, 6677 packets/sec
  30 second output rate 97456000 bits/sec, 9263 packets/sec
     2748252993 packets input, 417653764 bytes, 0 no buffer
     Received 58675 broadcasts (0 IP multicasts)
     0 watchdog, 58675 multicast, 0 pause input
     1421560591 packets output, 923787195 bytes, 0 underruns
 GigabitEthernet0/2
      1421787628 packets, 168725391504 bytes
      30 second offered rate 98514000 bps, drop rate 365000 bps
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops) 0/198203/0
      (pkts output/bytes output) 1421589425/168465124234
DR-2921#
DR-2921#
     reliability 255/255, txload 25/255, rxload 8/255
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 198930
  Output queue: 0/1000/1988781 (size/max total/drops)
  30 second input rate 32152000 bits/sec, 6760 packets/sec
  30 second output rate 99158000 bits/sec, 9438 packets/sec
     2748522222 packets input, 576456808 bytes, 0 no buffer
     Received 58679 broadcasts (0 IP multicasts)
     0 watchdog, 58679 multicast, 0 pause input
     1421936510 packets output, 1414220181 bytes, 0 underruns
 GigabitEthernet0/2
      1422163859 packets, 169219560972 bytes
      30 second offered rate 99093000 bps, drop rate 258000 bps
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops) 0/198930/0
      (pkts output/bytes output) 1421964931/168958339976
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Try increasing the shaper's max queue depth and/or increasing the shaper's Tc.
You might be getting gig microbursts that the shaper drops.
