IP SLA Monitor /Tracking 2921
GREGORY JACKSON
I am looking or IOS code for a Cisco 2921/K9 that will allow me to do IP SLA Tracking. The current code "c2900-universalk9-mz.SPA.151-4.M.bin" will only allow me to sset up IP SLA responder or IP SLA Server but  NOT IP SLA Monitor or IP SLA RTR.
I have used the Cisco feature set research tool and chose what it recommended but to no avail.
Am I missing something? Will the Server or Responder perform tracking?
Thanks in advance to anyone who can  assist..
~g
2 Accepted Solutions
raparash
hi,
please make sure you have the correct license set installed for the same.i think this is supported only on "IP DATA" license set and not on IP BASE.
you can check whether you have the correct license set installed or not by checking the show version output.
You can buy from any cisco reseller. You can enable a temporary license in the meanwhile.
6 Replies 6
raparash
hi,
You are corect I am licensed for IP-Base How do I get a license for IP Data?
bo2112260285
Dear All,
I have the same problem with C2921. I want to config IP SLA for my C2921 but it seems do not support. The below for your reference.
####### Do not have option monitor
ip sla ?
  key-chain  Use MD5 Authentication for IP SLAs Control Messages
  responder  Enable IP SLAs Responder
  server     IPPM server configuration
Show version
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M1.bin"
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2921/K9          FGL153913PM
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            None          None           None
data          None          None           None
Please kindly advise what ios I can use for configuring IP SLA. there're any problem with my licence for that
Best Regards,
Binh
By your output, it shows that you do not have the Data license, this is required to activate the SLA command set from what I understand.  But you can initialize the temp license:
from global config:
Router(config)#license boot module c2900 technology-package datak9
you will have to reload the router once you do this for the command set to be activated for use.
ip sla monitor is no longer part of the command set, Cisco has rolled in the monitor command within the ip sla command along with cutting out a bunch of stuff that really didn't need to be there.  Check out the new IOS command refference:
http://www.cisco.com/c/en/us/td/docs/ios/ipsla/command/reference/sla_book/sla_02.html#wp1052325
for example, on the old code:
ip sla monitor 1111
 type jitter dest-ipaddr 10.10.10.10 dest-port 17000 source-ipaddr 12.12.12.12 codec g729a
 tos 184
 tag VOIP-OS
New Code:
ip sla 1111
 udp-jitter 10.10.10.10 17000 source-ip 12.12.12.12 codec g729a
 tos 184
 tag VOIP-OS
Mark Walters
Hi All -
Just  an FYI, the best resource to find out exactly which features are  supported with which software license (IP Base vs Data in this case) is  with the Cisco Feature Navigator.  For devices that support licenses  (2900, ASR, etc) you'll have a dropdown box to select the different  licenses.
Cheers
Mark
