02-02-2015 04:06 AM - edited 03-05-2019 12:42 AM
Hi folks,
Is it possible to configure 3945 in-built Gigethernet ports 0/0, 0/1, 0/3 as switch-ports ?
Solved! Go to Solution.
02-02-2015 06:30 AM
No you can not use the switchport command on these interfaces. These interfaces are designed to be layer 3 interfaces and as such do not support the switchport command. As Aaron has suggested if you want layer 2 operation on these interfaces you can put them into a bridge group. But you can not use the switchport command on them.
Rick
02-03-2015 03:41 AM
No problem...
Please remember to rate replies and mark questions as 'answered' to highlight useful content...
Aaron
02-02-2015 04:14 AM
Not full featured switchports as such, but you can set them up as bridged ports.
Aaron
02-02-2015 06:30 AM
Thansk Aaron, so are 'switchport' commands possible on these ports ?
e.g.
interface GigabitEthernet0/0
switchport access vlan 300
switchport mode access
speed auto
duplex full
no shutdown
02-02-2015 06:30 AM
Rick
02-02-2015 09:45 AM
Thanks both Aaron and Richard for your info.
Cheers/
02-03-2015 03:41 AM
No problem...
Aaron
02-03-2015 03:27 AM
Hello!
I have 3925 and I was aggregate two interfaces to one Port-Channel.
And use subinterfaces on it
Theoretically, it is interfaces working like switchports, now
interface GigabitEthernet0/1
description N5K-1
no ip address
load-interval 30
duplex auto
speed auto
media-type rj45
channel-group 6
end
interface GigabitEthernet0/2
description N5K-2
no ip address
load-interval 30
duplex auto
speed auto
media-type rj45
channel-group 6
end
interface Port-channel6.3
interface Port-channel6.52
interface Port-channel6.69
interface Port-channel6.70
And more.
What You want to do?
02-03-2015 06:49 AM
The ability to put two interfaces that are naturally layer 3 interfaces into an Etherchannel and have them both operational and carrying traffic is very interesting. But it does not provide what I believe the original poster was looking for which is the ability to use switchport commands on the physical interfaces of the ISR G2 router.
Rick
