ISR 4000 and Cisco Feature Navigator
Mario Erceg
I want to find what feature set I need to buy in order to have some feature but Cisco feature navigator doesn't help for ISR 4000. Example: If I find feature "IP SLA ICMP .." in CFN it says all feature sets support this feature. But I know that IP BASE doesn't support.
How do you look for feature set of ISR 4000 for specific feature (example basic "IP SLA ICMP", "IPSec VTI" ...)?
6 Replies 6
Hi Mario,
IP SLA feature is supported on IP Base, Security, UC, APPX feature sets.
Please find the snapshot of Cisco Feature Navigator that shows this feature is supported on the above feature sets.
If this is helpful please give a thumbs up.
Spooster IT Services Team
The problem is that IP SLA is not supported on "IP BASE". My friend has 4331 router with "IP BASE" and has no this feature. Cisco Feature Navigator is wrong abaut ISR 4000 feature set.
Hi Mario,
Yes, it looks like Cisco Feature Navigator is providing wrong information.
For IP SLA support AX(Application Experience) license is required.
And for IPSec VPN support Security license is required.
http://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/datasheet-c78-732542.html
Do you know any other Cisco tool where I can find correct info about ISR 4000 features?
Hi Mario,
Following link has the information about ISR 4000 features supported and license required.
In this link there are following table has features information:-
Table 5.       Cisco 4000 Series Feature Bundles
Bundles
Features
Application Experience with Voice (AXV)
AX + Voice
Voice with Security (VSEC)
Voice + Security
Application Experience (AX)
IP Base + Security + advanced networking protocols: L2TPv3, BFD, MPLS, VRF, VXLAN[7](bandwidth less than 100 Mbps)
Application Experience: PfRv3, WAAS with AppNav, NBAR2, AVC, IPSLA
Hybrid Cloud Connectivity: LISP, OTV5 (for bandwidth less than 100 Mbps), Virtual Private LAN Services (VPLS), Ethernet over MPLS
Intelligent web caching: Akamai Connect
Voice (V)
IP Base + Unified Communications: Cisco Unified Communications Manager Express, Survivable Remote Site Telephony (SRST), CUBE
Security (SEC)
IP Base + Advanced Security: Zone-based firewall, IPsec VPN, EzVPN, Dynamic Multipoint VPN (DMVPN), FlexVPN
Please rate if this is helpful.
To all readers - note that AX license by itself does not include Security.
