04-26-2021 12:28 AM - edited 04-26-2021 12:36 AM
i have a 4000 series with a license for boost
the license appear on cisco website
and on the router
yet i cannot use it..
Version 16.6.4
SML is disabled
Installing...Feature:booster_performance...Failed:
% Error: Duplicate license
0/1 licenses were successfully installed
1/1 licenses were existing licenses
0/1 licenses were failed to install
show license feature
Feature name Enforcement Evaluation Subscription Enabled RightToUse
appxk9 yes yes no no yes
uck9 yes yes no no yes
securityk9 yes yes no no yes
ipbasek9 no no no yes no
FoundationSuiteK9 yes yes no no yes
AdvUCSuiteK9 yes yes no no yes
cme-srst yes yes no no yes
hseck9 yes no no no no
throughput yes yes no yes yes
internal_service yes no no no no
Index: 4 Feature: booster_performance Version: 1.0
License Type: Permanent
License State: Active, Not in Use
License Count: Non-Counted
License Priority: Medium
Store Index: 1
Index: 8 Feature: throughput Version: 1.0
License Type: RightToUse
License State: Active, In Use
License Priority: Low
Store Index: 6
platform hardware throughput level ?
100000 throughput in kbps
50000 throughput in kbps
license boot level ?
appxk9 Appx License Level
securityk9 Security License Level
uck9 Unified Communication License Level
Solved! Go to Solution.
04-26-2021 12:42 AM
- You may find hints, command, and requirements discussed in this thread useful :
M.
04-26-2021 12:42 AM
M.
04-26-2021 01:45 AM - edited 04-26-2021 07:04 AM
i will try to upgrade to 16.07.03 and apply the boost
thanks
update
this upgrade solve my issue
much thanks M
04-26-2021 01:39 AM
Is this new License, or after upgrade of IOS not working.
suggest to read this thread :
https://community.cisco.com/t5/switching/help-with-isr4331-evaluation-license/td-p/3178071
Still have issue please let us know.
04-26-2021 01:55 AM - edited 04-26-2021 01:57 AM
the license was first activated on version 17.01.01
04-26-2021 02:11 AM
So did you Downgraded ? from 17.X to 16X?
Then 16.9 onwards smart License, anything Lower is traditional License.
may be contact Licese team to sort this. what is the reason for downgrade ?
04-26-2021 04:13 AM - edited 04-26-2021 04:15 AM
same issue .. could not use the boost
we cant use CSL..
