ISR 4000 - VPN tunnel without encryption
danielsanmartin
Hi all.
Knowing the limitation of 85Mbps in the encryption of the ISR4000 routers, the use of a VPN tunnel without encryption will allow a greater bandwidth without limitations?
Daniel A. Sanmartin
yes correct, another question if you do not need encryption why you need ISR, you can consider L3 Switch or FW ?
Since we do not know requirement, can not suggest right one for you.
BB
7 Replies 7
balaji.bandi
yes you can get more bandwidth depends on License model.
check the model comparison.
https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/models-comparison.html
BB
Hi Balaji.
Thanks for the prompt response.
That is, the VPN tunnel without encryption will have a maximum bandwidth of 100Mbps in the case of an ISR4331 and 1Gbps for an ISR4451 without an additional license?
Daniel A. Sanmartin
BB
Our client has already purchased the ISR4000 equipment through a tender.
For administrative reasons, it is not possible to immediately purchase the HSEC license or performance or boost. That's why he's trying to make do with what he has.
Daniel A. Sanmartin
BTW, later ISR 4K IOS images now have a higher IPSec performance limit before needing a license upgrade.
Also BTW, don't forget, even with non-encrypted tunnels, you still want to configure to avoid IP fragmentation.
Hi Joseph.
A higher IPSec performance in later ISR 4K IOS images applies only to ISR4451X or the entire ISR4000 series?
Daniel A. Sanmartin
Unsure, but the lower end 4K ISRs may not offer enough base performance to take advantage of the increase.
