ISR 4221 Guestshell Network Access
crench92
So I read that as of IOS XE 16.8.1, you can enable the guestshell with only 4G of RAM which is what our ISR 4221s have.  How do we configure this? I get the following when trying:
Test_host#guestshell enable
Interface will be selected if configured in app-hosting
Please wait for completion
% Error: No interface configuration for guestshell
The goal is to get iperf on the guestshell and talking to another iperf server.  Is this possible using Gi0/0/0 on the router with some kind of NAT?
18 Replies 18
gnijs
Level 4
Level 4
Got the same error Cat9300 16.8.1a when doing "guestshell enable"
ok, so i found this (might help)
you need to add the following:
app-hosting appid guestshell
 vnic management guest-interface 0
end
i found this on a C9500. It seems to be automatically added on this platfrom.
But on a C9300, after an upgrade to 16.8.1a, it might be missing and hence guestshell won't start.
After adding the above, it worked.
So I've managed to get past this by switching around the order in Cisco's documentation and added this before enabling:
app-vnic gateway0 virtualportgroup 0 guest-interface 0
  guest-ipaddress 192.168.35.2 netmask 255.255.255.0
app-default-gateway 192.168.35.1 guest-interface 1
app-resource profile custom
  cpu 800
  memory 256
But now i get the following:
HUWANOR1TLHS0164NR01#guestshell enable
% Error: Application ext2 disk is missing! : /bootflash/iox/repo/guestshell/extract_archive/guestshell.ext2
There any update on trying to find out why this error is happening?
Is there any external media installed such as a USB disk? I found it was creating some directories on the usbflash0: by default and seemed to have a problem finding them later. I removed the USB stick, destroyed the guestshell and disabled iox, re-enabled iox and then was able to get guestshell to enable properly.
I wanted to post this for anyone with 9300 switches for Guest shell to work:
this worked for me.
Enable Right-to-use license for app-hosting (this is required) and reboot switch
  • Switch(config)#license right-to-use activate addon dna-advantage subscription acceptEULA
  • Switch# ReloadAdd smart License for App-Hosting.
  • Switch(config)#license boot level network-advantage addon dna-advantage
Configure a management Interface for "guestshell enable" mode:
  • Switch(config-app-hosting)#vnic management guest-interface 0 guest-ipaddress <IPAddress> netmask <subnetmaskIP> gateway <IPAddress> name <nameserverIPaddress>
Enable Guest shell:
  • switch#guestshell enable
guestshell activated successfully
Current state is: ACTIVATED
guestshell started successfully
Current state is: RUNNING
Guestshell enabled successfully
Verify guestshell is in running state.
Switchk#show app-hosting list
App id                           State
guestshell                       RUNNING
Now go try guestshell command:
Switch#guestshell
[guestshell@guestshell ~]$
I hope this helps anyone....
This means your install is incomplete or corrupted..., need to redo
Mahmoud Manaa
vstepanov
the same problem on catalyst 9300 IOS-XE 16.9.2. At the same time it works on catalyst 9300 IOS-XE 16.6.1
UBU-01#guestshell enable
% Error: Error while creating container XML error: Domain interface: Missing required gateway attribute in route definition
Hi Richard,
I will be happy to help you. Have you resolved this problem? in case you don't, please share with me your current configuration.
Thank you.
Eduardo
I have same problem -
% Error: Error while creating domain XML error: Domain interface: Missing required gateway attribute inroute definition.
C4331-1#sh app-hosting list
App id State
guestshell DEPLOYED
Did you find any workaround for the same.
Amit
configure gateway attribute on
conf ter
vnic gateway1 virtualportgroup 0 guest-interface 0 ---> blah blah blah
csr1000v#guestshell enable
