MY CISCO ID(CSCO) at Netacad and Pearson Vue are not the Same
The account merge can be done by CISCO Itself, Therefore I would request you to please connect with CISCO.
I need help.
pieterh
if you do not specify your existing CSCO-ID when entering a certification exam , you will end up with mutliple ID's
this cannot be solved by the cisco community (users of Cisco equipment,) , you need to contact Cisco directly to solve this
How can I contact them ???
johnlloyd_13
Level 9
Level 9
hi,
i believe the netacad and pearson VUE (cisco) are diffferent and independent login accounts.
are you booking for a cisco exam or check your cert status?
try to contact cisco cert support (CCO login required).
select certification > choose a specific topic > click 'open a case' at the bottom:
www.cisco.com/go/certsupport
mukhtiar88
please need support i have two account and two Cisco ID i want to Merge it how its possible
