03-17-2022 09:20 PM
Hey Guys,
I have tried to upgrade ISR4331 without upgrading bootloader first and now it is stuck in a boot loop
I'm trying to send a break command but nothing is happening.
Initializing Hardware ...
System integrity status: 00000610
Rom image verified correctly
System Bootstrap, Version 15.4(3r)S5, RELEASE SOFTWARE
Copyright (c) 1994-2015  by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
Cisco ISR4331/K9 platform with 4194304 Kbytes of main memory
boot: unsupported boot device "isr4300-universalk9.16.09.01.SPA.bin"
autoboot: boot failed, restarting...
no valid BOOT image found
Final autoboot attempt from default boot device...
Warning: filesystem is not clean
File size is 0x00000482
Located XXXXXXXXX.lic
Image size 1154 inode num 12, bks cnt 1 blk size 8*512
Boot image size = 1154 (0x482) bytes
Unknown image structure
File size is 0x00000183
Located tracelogs.260
Image size 387 inode num 13, bks cnt 1 blk size 8*512
Boot image size = 387 (0x183) bytes
File size is 0x0000001e
Located throughput_monitor_params
Image size 30 inode num 14, bks cnt 1 blk size 8*512
Boot image size = 30 (0x1e) bytes
Unsigned package found,  aborting ...
File size is 0x22c1151d
Located isr4300-universalk9.16.09.01.SPA.bin
Image size 583079197 inode num 16, bks cnt 142354 blk size 8*512
Boot image size = 583079197 (0x22c1151d) bytes
Package header rev 3 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
        calculated 595cdb24:b9751f91:731a4622:7034be2b:f11d9c77
        expected   595cdb24:b9751f91:731a4622:7034be2b:f11d9c77
RSA Signed RELEASE Image Signature Verification Successful.
Package Load Test Latency : 10573 msec
boot: cannot determine first file name on device "bootflash:/"
autoboot: boot failed, restarting...Is there anything I can do to force it into ROMMON or boot of USB?
03-17-2022 09:43 PM - edited 03-17-2022 09:57 PM
If the router is in ROMMON, post the complete output to the following commands:
03-18-2022 12:33 AM
Hi Leo,
No sorry, it just keeps looping and restarting.
I am trying to send BREAK via putty but it just keeps rebooting and that is it. Any advice on how to get it in to ROMMON?
03-18-2022 12:40 AM - edited 03-18-2022 01:07 AM
Post the boot-up process.
I cannot diagnose without the right information.
I cannot tell if the router is in a boot-crash-loop or trying to load an incompatible firmware file and booting.
Otherwise, raise a TAC Case.
03-18-2022 06:25 AM
03-18-2022 06:51 AM
@xXAzazelXx wrote:
Unknown image structure Warning: filesystem is not clean File size is 0x00000183 Located tracelogs.260 Image size 387 inode num 13, bks cnt 1 blk size 8*512
Contact Cisco TAC and organize for an RMA. The flash is dead.
03-18-2022 06:34 PM
It's a second-hand device, there is no TAC, but thank you for the reply.
03-18-2022 09:48 AM
- Try fsck flash:
M.
03-18-2022 06:33 PM
Thank you but I cant get in to ROMMON or the XE to action this sorry, its just keeps rebooting.
03-18-2022 12:55 AM
what was the before version, and what version you upgrade to ? (this information help us also)
as mentioned other post, try to break in to ROMMON
follow steps to get into ROMMON :
If you have the image in USB, try to boot from USB and see if the router boots?
03-18-2022 06:38 AM
Thank you,
I'm not sure what the previous version was sorry, it's been bricked for a while.
Thank you for the link but looks like the instructions are only if you can already login to the device to set the confreg, but since mine is looping I am unable to do so.
I do have the image and can copy it onto the USB but since I cant get into ROMMON I cant boot from USB unless there is another way?
03-18-2022 07:57 AM
the instruction given to break the key to get in to ROMMON.
03-18-2022 01:37 AM - edited 03-18-2022 01:56 AM
In my opinion, you have your bootflash: file system damaged
You can try to re-format your flash by issuing a
format flash:
command.
But remember to do a config backup first!!!
After the formatting, copy these config file back.
By the way, while booting, you can change the Serial Port Speed to 1200 and hold SPACE bar on boot up for 10-30 sec.
It may help to entering the ROMMON mode, dont forget to config speed back to 9600 to interact with ROMMON terminal.
03-18-2022 01:52 AM
I noticed two lines of log:
boot: cannot determine first file name on device "bootflash:/" boot: unsupported boot device "isr4300-universalk9.16.09.01.SPA.bin"
In my opinion, you may wrongly type the image config command
boot system isr4300-universalk9.16.09.01.SPA.bin or boot system bootflash:/ or something else
instead of:
boot system flash:/isr4300-universalk9.16.09.01.SPA.bin
Which makes the Bootloader think "isr4300-universalk9.16.09.01.SPA.bin" or "bootflash:/" is your boot device, but non of the boot image is on them.
To solve the problem, you can try to boot up without loading any configuration. You can find out how to do it, it is same to Password Recovery. Usually executing a confreg 0x<something> after entering the ROMMON
The way may help to abort the boot up and enter rommon 0> command mode are provided above, you can try it.
03-18-2022 06:44 AM
Thank you for your comments,
Well, part of the problem is that I cannot get int to the ROMMON mode.
The device is just stuck in the reloading loop so I cannot set the config values.
I've tried putty, SecureCRT etc and I just spam it with a break key to no success.
I've tried setting the speed to 1200 as you mentioned and holding down space bar for a while and switching back.
Is there anything else i can try?
