ISR 4300 - Stuck In Boot Loop after upgrade
xXAzazelXx
Hey Guys,
I have tried to upgrade ISR4331 without upgrading bootloader first and now it is stuck in a boot loop
I'm trying to send a break command but nothing is happening.
Initializing Hardware ...
System integrity status: 00000610
Rom image verified correctly
System Bootstrap, Version 15.4(3r)S5, RELEASE SOFTWARE
Copyright (c) 1994-2015  by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
Cisco ISR4331/K9 platform with 4194304 Kbytes of main memory
boot: unsupported boot device "isr4300-universalk9.16.09.01.SPA.bin"
autoboot: boot failed, restarting...
no valid BOOT image found
Final autoboot attempt from default boot device...
Warning: filesystem is not clean
File size is 0x00000482
Located XXXXXXXXX.lic
Image size 1154 inode num 12, bks cnt 1 blk size 8*512
Boot image size = 1154 (0x482) bytes
Unknown image structure
File size is 0x00000183
Located tracelogs.260
Image size 387 inode num 13, bks cnt 1 blk size 8*512
Boot image size = 387 (0x183) bytes
File size is 0x0000001e
Located throughput_monitor_params
Image size 30 inode num 14, bks cnt 1 blk size 8*512
Boot image size = 30 (0x1e) bytes
Unsigned package found,  aborting ...
File size is 0x22c1151d
Located isr4300-universalk9.16.09.01.SPA.bin
Image size 583079197 inode num 16, bks cnt 142354 blk size 8*512
Boot image size = 583079197 (0x22c1151d) bytes
Package header rev 3 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
        calculated 595cdb24:b9751f91:731a4622:7034be2b:f11d9c77
        expected   595cdb24:b9751f91:731a4622:7034be2b:f11d9c77
RSA Signed RELEASE Image Signature Verification Successful.
Package Load Test Latency : 10573 msec
boot: cannot determine first file name on device "bootflash:/"
Is there anything I can do to force it into ROMMON or boot of USB?
19 Replies 19
Have your machine got internal flash?
Maybe you can pull the flash out, it may enter ROMMON when it cant find the flash.
Or after ##########################
Boot image size = 583079197(0x22c1151d) bytes
is displayed, give a BREAK sequence slowly (about 5 - 8 secs between 2 taps) .
It may help to enter ROMMON
Thank you, but still no go
Can you open the machine and directly access to bootflash?
It's an ISR4331, from what I've read the flash is onboard somewhere but I'm happy to be wrong.
There is an expansion slot but i don't know where the onboard flash is.
I had a similar issue with a ROMMON loop exactly as per the first post. There was no prompt, just continuously cycling, I managed to break it with a simple CTRL+C and it reset immediately to the rommon1> prompt.
