11-12-2021 01:00 PM
If provided a Public WAN IP and a set of Public LAN IPs, where would I assign the Public LAN IPs?
I have the WAN IP assigned to the Gb0/0/0 Port.
I am unable to assign the LAN Public IPs to the actual NIM card slots, so would I assign the Public LAN IPs to VLANs?
Solved! Go to Solution.
11-30-2021
10:17 AM
- last edited on
12-01-2021
11:26 PM
by
Translator
Hello
Your nat configuration looks like it has statements that are not necessary, pointing to the wrong wan interface, conflicting access-list or ones that don’t even exist and multiple overload statements that just single one could accomplish?
Suggest the following:
no ip nat inside source route-map track-primary-if interface GigabitEthernet0/0/0 overload
no ip nat pool testnet 209.Y.Y.Y 209.Y.Y.Y netmask 255.255.255.192
no ip nat pool HbugPool 209.X.X.X 209.X.X.X netmask 255.255.255.192
no ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
no ip nat inside source list 15 interface GigabitEthernet0/0/1 overload
no ip access-list standard 1
no ip access-list standard 10
no ip access-list standard 15
ip access-list standard10
deny(specfic lan subnet)
deny host 192.168.1.100
deny host 10.10.10.197
deny host 10.10.10.7
deny host 10.10.10.32
deny host 192.168.1.101
deny host 192.168.2.50
permit 10.0.0.0 0.255.255.255
permit 192.168.2.0 0.0.0.255
permit 192.168.1.0 0.0.0.255
permit 172.16.0.0 0.0.255.255
permit etc...
ip access-list standard newpat
permit (specfic lan subnet)
ip nat pool new-public-ip y.y.y.y y.y.y.y netmask x.x.x.x
ip nat inside source list newpat pool new-public-ip
11-12-2021 02:03 PM
indeed you can assign the public LAN IP addresses to either the SVI (Vlan) interfaces, or one of the other physical layer 3 interfaces you have...
11-22-2021 12:58 PM - edited 11-22-2021 12:58 PM
I've tried to assign it as the IP of the vlan, but when I go to ipcow or ipchicken it still shows the main WAN IP instead of my preferred Public IP from the pool of IP addresses I received from my ISP.
11-22-2021 01:49 PM
post your full running configuration...
11-30-2021 06:51 AM - edited 11-30-2021 06:53 AM
Here's what I've got right now. Any help would be appreciated. I want 209.X.X.X to be the public ip for all users on VLAN4 (ip range 10.x.x.x).
Note: I have a test VLAN where I can try to get VLAN5 (172.16.x.x) to look as if it's "209.G.G.G" until after hours when I could make changes for the live connection.
11-13-2021
01:54 AM
- last edited on
12-01-2021
11:17 PM
by
Translator
This means they are just Layer 2 Modules, best is configure SVI
config t
Interface vlan X ( vlan X what ever vlan you like to use)
x.x.x.x 255.255.255.0
no shutdown
configure the interface belong to that vlan
config t
interface g x/x
switchport mode access
switchport access vlan x
no shutdown
hope this helps you.
11-22-2021 11:30 PM - edited 11-22-2021 11:36 PM
Hello
you cannot assign additional public ip address thats in the same subnet of your existing public ip to another interface on the same rtr! unless yo implement VRF
You could apply them as secondaries on gig0/0/0 or use them for one to one static nat
11-23-2021 06:44 AM
11-23-2021 11:30 PM
Hello
you won’t be able to assign it to a subinterface either as you will get error stating address range already being in use unless it’s in its own vrf
i said it can be assigned as a secondary on gig0/0/0
what is the reason you want to use this additional public address
11-29-2021 07:17 AM
11-29-2021 07:48 AM
I believe that the previous suggestion to use one to one static nat is the better alternative to use those addresses.
11-29-2021 08:12 AM - edited 11-29-2021 08:13 AM
Problem is I need several computers to look like they have that NAT address, so I believe I'm leaning more into PAT territory. I'm going to try the secondary IP option tonight (in case I disrupt service accidentally) and see if that works out for me. If it doesn't, I'll have to see about using the one extra Layer 3 port to use the address. I was hoping to use a Layer 2 port from the NIM expansion (in conjunction with a VLAN), but either I keep misconfiguring or it's just not possible and I need to use the Layer 3 port. I'm sure I keep misconfiguring something though.
11-30-2021 07:01 AM - edited 11-30-2021 08:02 AM
Hello
you don’t need to add a secondary ip address to accomplish this -you can have nat to point to a public ip that you own all you need is for that new ip address to be reachable to your network and if your isp is advertising it already then it should be good
11-30-2021 07:27 AM
Where am I assigning the second IP address to?
11-30-2021 08:02 AM
Hello
You don’t it will only relate to the nat statement for the users you want to be natted
externally they will be seen via this additional public ip as i stated previously its already being advertised and routed to your wan rtr by your isp anyway
Can you provide your exiting nat configuration please for review
