ISR 900 L2TP VPN connection
T0mTheCat
Hi, I am trying to configure L2TP remote connection back to office, however when I try to add the crypto map to my interface i get "Cannot apply empty map to interface" what am I missing?
R1(config)#int
R1(config)#interface gig5
R1(config-if)#cry
R1(config-if)#crypto map
R1(config-if)#crypto map avita
R1(config-if)#
my config is below, much appreciate your help! =D
R1#show run
R1#show running-config
Building configuration...
Current configuration : 4614 bytes
! Last configuration change at 16:05:57 UTC Sun May 23 2021 by admin
version 15.8
service timestamps debug datetime msec localtime
service timestamps log datetime localtime
hostname R1
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login avitavpn local
aaa authorization network avitanet local
aaa session-id common
memory-size iomem 25
clock timezone UTC 8 0
ip dhcp excluded-address 192.168.2.1 192.168.2.50
ip dhcp excluded-address 192.168.2.98 192.168.2.101
ip dhcp pool pool1
import all
network 192.168.2.0 255.255.255.0
dns-server 165.21.83.88 165.21.100.88 8.8.8.8
default-router 192.168.2.1
ip domain lookup source-interface GigabitEthernet5
ip domain name avitasg.webhop.org
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip ddns update method dyndns
ip cef
no ipv6 cef
vpdn enable
vpdn-group g-l2tp
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 1
no l2tp tunnel authentication
license accept end user agreement
license boot module c900 technology-package securityk9
redundancy
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
lifetime 3600
crypto isakmp key xxxx address 0.0.0.0
crypto isakmp client configuration group avitanet
key xxxx
pool avita
crypto ipsec transform-set avita esp-3des esp-sha-hmac
mode transport
crypto dynamic-map avita 1
set nat demux
set transform-set avita
interface GigabitEthernet0
switchport access vlan 250
switchport mode access
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
shutdown
duplex auto
speed auto
ip ddns update hostname avitasg.webhop.org
ip ddns update dyndns
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered GigabitEthernet5
peer default ip address pool l2tp-pool
ppp authentication ms-chap-v2
interface Vlan1
no ip address
interface Vlan250
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip local pool l2tp-pool 10.10.10.10 10.10.10.15
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 1 interface GigabitEthernet5 overload
ip nat inside source static tcp 192.168.2.200 9999 interface GigabitEthernet5 9999
ip nat inside source static tcp 192.168.2.200 81 interface GigabitEthernet5 81
ip nat inside source static tcp 192.168.2.200 8000 interface GigabitEthernet5 8000
ip nat inside source static tcp 192.168.2.99 445 interface GigabitEthernet5 445
ip nat inside source static udp 192.168.2.99 137 interface GigabitEthernet5 137
ip nat inside source static udp 192.168.2.99 138 interface GigabitEthernet5 138
ip nat inside source static tcp 192.168.2.99 139 interface GigabitEthernet5 139
ip nat inside source static tcp 192.168.2.99 465 interface GigabitEthernet5 465
ip nat inside source static tcp 192.168.2.61 3389 interface GigabitEthernet5 3389
ip nat inside source static udp 192.168.2.99 1701 interface GigabitEthernet5 1701
ip nat inside source static udp 192.168.2.99 500 interface GigabitEthernet5 500
ip nat inside source static udp 192.168.2.99 4500 interface GigabitEthernet5 4500
ip nat inside source static udp 192.168.2.99 1194 interface GigabitEthernet5 1194
ip nat inside source static tcp 192.168.2.99 137 interface GigabitEthernet5 137
ip nat inside source static tcp 192.168.2.99 138 interface GigabitEthernet5 138
ip nat inside source static tcp 192.168.2.99 5001 interface GigabitEthernet5 5001
ip route 0.0.0.0 0.0.0.0 GigabitEthernet5 dhcp
snmp-server group snmpv3grp v3 auth
access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
line con 0
password xxx
line vty 0 4
password xxx
transport input ssh
line vty 5 15
transport input ssh
scheduler allocate 20000 1000
end
Post the full configuration (updated on)  - enable-debug to understand the issue.  - other thing noticed avitanet already used, use other name here, did your Router exposed to interenet, how is user conecting to what IP address ?
window 10 vpn connection unable to went thru at "verification"
what error you get on client. ?
Look at the below example :
https://content.cisco.com/chapter.sjs?uri=%2Fsearchable%2Fchapter%2Fcontent%2Fen%2Fus%2Ftd%2Fdocs%2Fios-xml%2Fios%2Fsec_conn_vpnips%2Fconfiguration%2F15-mt%2Fsec-sec-for-vpns-w-ipsec-15-mt-book%2Fl2tp-ipsec-sup-nat-pat-win-clients.html.xml&platform=C...
https://www.cisco.com/en/US/docs/ios-xml/ios/sec_conn_vpnips/configuration/15-2mt/l2tp-ipsec-sup-nat-pat-win-clients.html
https://www.cisco.com/c/en/us/support/docs/dial-access/virtual-private-dialup-network-vpdn/200450-Setting-up-L2TP-Tunnel-between-a-Windows.html
BB
18 Replies 18
balaji.bandi
i believe you need to map as an example below :
crypto map BBB 1 ipsec-isakmp dynamic avita   <--- change the BBB to your own.
Then apply to the interface.
R1(config-if)#crypto map BBB
then you see a console message :
%CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
BB
Hi Balaji,
I did not see that line, however i use window 10 vpn connection unable to went thru at "verification"
any idea?
R1(config)#crypto map avitanet 1 ipsec-isakmp dynamic avita
R1(config)#int
R1(config-if)#cry
R1(config-if)#crypto map avitanet
R1(config-if)#
R1(config-if)#exit
R1(config)#exit
R1#
BB
Hi Balaji,
*window 10 vpn connection unable to went thru at "verification"
Sorry the error earlier it was a mistake, i forgot to disconnect my vpn to my synology NAS, please ignore
Yes the router exposed to internet, user should be just using their own internet, and getting DHCP for VPN connection
Sorry, how do I get the debug enable?
Now I get below error instead
Current configuration : 4734 bytes
! Last configuration change at 13:46:59 UTC Mon May 24 2021 by admin
version 15.8
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$ZdLb$ZJ
aaa new-model
aaa authorization network default local
ip dhcp pool pool1
import all
ip cef
no ipv6 cef
vpdn enable
vpdn-group g-l2tp
accept-dialin
protocol l2tp
virtual-template 1
license udi pid C921-4P sn
username admin secret 5 $1$H.hT$XUDCemW
username avita password 0 xxx
redundancy
encr 3des
group 2
lifetime 3600
crypto isakmp key xxx address 0.0.0.0
crypto isakmp client configuration group avitaWFH
key xxx
pool avita
mode transport
set nat demux
crypto map avitaWFH 65535 ipsec-isakmp dynamic avita
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
crypto map avitaWFH
interface Vlan1
no ip address
interface Vlan250
ip nat inside
no ip http server
ip dns server
control-plane
line con 0
password avita0108
line vty 0 4
password avita0108
transport input ssh
line vty 5 15
transport input ssh
end
First we need to check make sure the request passing your Internet FW and reaching the Router ?
run debug - debug ppp negotiation
https://www.cisco.com/c/en/us/support/docs/dial-access/virtual-private-dialup-network-vpdn/20980-vpdn-20980.html
BB
Hi Balaji,
We do not have a firewall
R1#debug ppp negotiation
PPP protocol negotiation debugging is on
Much appreciate your help! =D
then how is this device exposed to Internet, i was only advising to check is the Packets or traffic allowed inside to this router  First before we get on other issues.
BB
Hi Balaji,
There is a modem connected directly to gig5 port to the internet, yes, local network and internet inside is all working fine.
Thank you.
is this ISP Modem ? is this have feature to port-forward outside to inside settings ?
Internet work inside to outside, the concern here outside to inside ?  enable debug and test client see any incoming connections ?
BB
Hi Balaji,
Thank you for your prompt respond, yes is a Fibre Optics ONT ISP modem, however this modem is configured only for DHCP Public IP.
I do not think there is any port forward or setting be done there.
I believe debug is enable, how to test client incoming connection?
Thank you.
if it connected to ONT, then your device need to act as Router make Port-forward for the L2TP connection.
is the DHCP from provide is Public IP address ? which is assinged to your router
can you post show ip interface brief and show ip route
BB
Hi Balaji,
*is the DHCP from provide is Public IP address ? which is assinged to your router*
Yes, you are right
R1#show ip interface brief
GigabitEthernet0 unassigned YES unset up up
GigabitEthernet1 unassigned YES unset up up
GigabitEthernet2 unassigned YES unset up up
GigabitEthernet3 unassigned YES unset down down
GigabitEthernet4 unassigned YES NVRAM administratively down down
GigabitEthernet5 128.106.149.52 YES DHCP up up
NVI0 unassigned YES unset up up
Virtual-Access1 unassigned YES unset down down
Virtual-Template1 128.106.149.52 YES unset down down
Vlan1 unassigned YES unset down down
Vlan250 192.168.2.1 YES NVRAM up up
R1#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 128.106.149.254 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 128.106.149.254, GigabitEthernet5
128.106.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 128.106.149.0/24 is directly connected, GigabitEthernet5
L 128.106.149.52/32 is directly connected, GigabitEthernet5
192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.2.0/24 is directly connected, Vlan250
L 192.168.2.1/32 is directly connected, Vlan250
please advise what will be the port forward command?
thank you.
In  this you do not need any port forward, since the router directly connected to Internet.  ( from Internet are you able to ping your Public side IP address?)
i see couple of issue with config - authenticaiton and other stuff (i may be outside can not check line by line to confirm)
use below exact document for your setup to work :
https://community.cisco.com/t5/security-documents/l2tp-over-ipsec-on-cisco-ios-router-using-windows-8/ta-p/3142831
BB
Hi Balaji,
yes, able to ping
Any idea why "hash sha" never show up but "hash md5" do?
show run -
encr 3des
hash md5
group 2
