04-03-2023 07:33 AM
Hello community,
I have a cisco ISR 4331 router at my client, with:
IOS image: 17.06.01a
Rommon image: 17.6.2
I want to downgrade IOS image from 17.06.01a to 17.02.01, but I get the error: Image is not compatible with system.
Other versions i tried: 17.04.01, 17.02.01, same error.
Find the error attached below.
Best regards,
BR.
04-03-2023 09:15 AM
- Check ROMMON compatibilities too , sometime if rommon upgrade was done to support newer versions, then 'immediate downgrade' may no longer be possible...
M.
04-03-2023 09:17 AM
ROMMON can not be downgradble, the IOS downgrade and device works as expected.
i would download again image from cisco side check the MD5 checksum.
Can you also post show versios and dir (full here)
04-03-2023 09:24 AM
                        >...ROMMON can not be downgradble,
  - Following on that , the customer may want to formulate the 'reasonable requirements' for a downgrade...
M.
04-03-2023 09:51 AM
Thanks for reply.
Here you find, show version and dir:
show version:
Cisco IOS XE Software, Version 17.06.01a
Cisco IOS Software [Bengaluru], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.6.1a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Sat 21-Aug-21 03:27 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2021 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: (c)
Router_Bangladesh uptime is 2 hours, 35 minutes
Uptime for this control processor is 2 hours, 37 minutes
System returned to ROM by Reload Command at 14:03:30 UTC Mon Apr 3 2023
System image file is "bootflash:isr4300-universalk9.17.06.01a.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None Smart License None
securityk9
appxk9
AdvUCSuiteK9 None Smart License None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None Smart License None
uck9 uck9 Smart License uck9
securityk9 securityk9 Smart License securityk9
ipbase ipbasek9 Smart License ipbasek9
The current throughput level is 100000 kbps
Smart Licensing Status: Registration Not Applicable/Not Applicable
cisco ISR4331/K9 (1RU) processor with 1699220K/3071K bytes of memory.
Processor board ID FDO2642M1FC
Router operating mode: Autonomous
2 Virtual Ethernet interfaces
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:.
7862242K bytes of USB flash at usb0:.
dir:
Directory of bootflash:/
136545 drwx 81920 Apr 3 2023 16:42:29 +00:00 tracelogs
72290 drwx 4096 Apr 3 2023 14:10:27 +00:00 license_evlog
18 -rw- 30 Apr 3 2023 14:10:10 +00:00 throughput_monitor_params
14 -rw- 134935 Apr 3 2023 14:09:59 +00:00 memleak.tcl
80321 drwx 4096 Apr 3 2023 14:09:58 +00:00 .prst_sync
12 -rw- 2456 Apr 3 2023 14:09:27 +00:00 mode_event_log
184737 drwx 4096 Apr 3 2023 14:09:23 +00:00 core
104417 drwx 4096 Apr 3 2023 14:08:59 +00:00 .installer
16065 drwx 4096 Apr 3 2023 14:08:42 +00:00 sysboot
13 -rw- 742995706 Apr 3 2023 14:00:29 +00:00 isr4300-universalk9.17.04.01a.SPA.bin
17 -rw- 656 Mar 7 2023 14:16:11 +00:00 vlan.dat
176705 drwx 4096 Mar 7 2023 13:45:24 +00:00 .dbpersist
176707 drwx 4096 Mar 7 2023 13:19:40 +00:00 pnp-tech
39 -rw- 215 Mar 7 2023 13:19:29 +00:00 .iox_dir_list
104421 drwx 4096 Oct 13 2022 08:18:02 +00:00 .geo
21 -rw- 788466100 Oct 13 2022 08:09:02 +00:00 isr4300-universalk9.17.06.01a.SPA.bin
144578 drwx 4096 Oct 13 2022 08:06:08 +00:00 iox_host_data_share
88354 drwx 4096 Oct 13 2022 08:05:47 +00:00 guest-share
152609 drwx 4096 Oct 13 2022 08:05:21 +00:00 onep
144577 drwx 4096 Oct 13 2022 08:05:20 +00:00 pnp-info
96385 drwx 4096 Oct 13 2022 08:04:51 +00:00 virtual-instance
16 -rwx 1314 Oct 13 2022 08:04:47 +00:00 trustidrootx3_ca.ca
15 -rw- 20109 Oct 13 2022 08:04:47 +00:00 ios_core.p7b
112449 drwx 4096 Oct 13 2022 08:04:02 +00:00 .rollback_timer
11 drwx 4096 Oct 13 2022 08:03:30 +00:00 lost+found
3258179584 bytes total (782110720 bytes free)
04-03-2023 04:08 PM
@Mark Elsen, @balaji.bandi, IOS-XE version 17.2.1r is not a ROMMON file.
Apparently, someone in Cisco has decided to call 17.2.1 an "r" because it can do, get this, "routing". (IOS XE 17.2.1r: Single again and Ready to Mingle!)
