ISR4321 - adding second S2S VPN, phase 2 not coming up
train_wreck
I have a 4321 ver. 15.5 that has a certificate authentication IKEv2 site to site tunnel setup to an ASA. This tunnel is working fine.
I am adding a second S2S tunnel to a Cisco RV340 router. Phase 1 is coming up OK, but phase 2 never establishes. The RV340 thinks that everything is fine and the phase 2 is up, but the ISR does not.
Config:
Current configuration : 9407 bytes
! Last configuration change at 00:16:41 CDT Thu May 23 2019 by user
version 15.5
service password-encryption
no platform punt-keepalive disable-kernel-core
platform hardware throughput level 100000
hostname 4321-pLAN9-co
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 5 xxxxx
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone CDT -5 0
clock summer-time CDT recurring 1 Sun Nov 2:00 2 Sun Mar 2:00
ip name-server 75.75.75.75
ip dhcp excluded-address 192.168.211.2
ip dhcp pool DHCP
 network 192.168.211.0 255.255.255.248
 default-router 192.168.211.1
 dns-server 192.168.211.1
 lease 0 0 10
subscriber templating
crypto pki trustpoint pLAN9
 enrollment terminal
 fqdn none
 subject-name CN=4321.pLAN9.co
 revocation-check none
 rsakeypair MAINRSA
crypto pki certificate map CERTMAP 10
 issuer-name co  = CA_COMMON_NAME
crypto pki certificate chain pLAN9
 certificate 00CF75E3A8D2772F2D
xxxxxxxxxxxxxxxxxxxxxx
        quit
 certificate ca 00A64BD6B54544EEC6
        quit
license udi pid ISR4321/K9 sn FDO21032NET
username user password 7 xxxxxx
redundancy
 mode none
crypto ikev2 proposal aes256-sha1
 encryption aes-cbc-256
 integrity sha1
 group 5
crypto ikev2 policy policy
crypto ikev2 profile ASA
 match certificate CERTMAP
 identity local dn
 authentication local rsa-sig
 authentication remote rsa-sig
 lifetime 28800
no crypto ikev2 http-url cert
vlan internal allocation policy ascending
no cdp run
class-map type inspect match-any ALL
 match protocol tcp
 match protocol udp
 match protocol icmp
class-map type inspect match-any EXPOSED
 match access-group name EXPOSED
policy-map type inspect OUT_IN_POL
 class type inspect EXPOSED
  inspect
 class class-default
  drop log
policy-map type inspect SELF_OUT_POL
 class type inspect ALL
  inspect
 class class-default
  drop log
policy-map type inspect IN_OUT_POL
  inspect
 class class-default
  drop log
policy-map type inspect OUT_SELF_POL
  inspect
 class class-default
  drop log
zone security INSIDE
zone security OUTSIDE
zone-pair security IN_OUT_ZONE source INSIDE destination OUTSIDE
 service-policy type inspect IN_OUT_POL
zone-pair security OUT_IN_ZONE source OUTSIDE destination INSIDE
 service-policy type inspect OUT_IN_POL
zone-pair security OUT_SELF_ZONE source OUTSIDE destination self
 service-policy type inspect OUT_SELF_POL
zone-pair security SELF_OUT_ZONE source self destination OUTSIDE
 service-policy type inspect SELF_OUT_POL
crypto isakmp identity dn
crypto ipsec transform-set aes256-sha1 esp-aes 256 esp-sha-hmac
 mode tunnel
crypto ipsec profile profile
 set transform-set aes256-sha1
 set ikev2-profile ASA
crypto map MAP 10 ipsec-isakmp
 set peer ASA_WAN_IP
 set security-association lifetime kilobytes disable
 set security-association lifetime seconds 28800
 set pfs group5
 match address VPN_1176
crypto map MAP 20 ipsec-isakmp
 set peer RV340_WAN_IP
 set pfs group5
 match address VPN_340
interface GigabitEthernet0/0/0
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/1
 ip address ISR4321_WAN_IP 255.255.255.248
 ip nat outside
 zone-member security OUTSIDE
 negotiation auto
 crypto map MAP
interface GigabitEthernet0/1/0
 switchport access vlan 20
 switchport mode access
 spanning-tree bpdufilter enable
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
interface Vlan1
 no ip address
 shutdown
interface Vlan20
 ip address 192.168.211.1 255.255.255.248
 ip nat inside
 zone-member security INSIDE
ip nat inside source list NAT interface GigabitEthernet0/0/1 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip dns server
ip route 0.0.0.0 0.0.0.0 DEFAULT_GATEWAY
ip route 192.168.34.0 255.255.255.240 RV340_WAN_IP
ip route 192.168.222.0 255.255.255.224 ASA_WAN_IP
ip ssh source-interface Vlan20
ip access-list extended EXPOSED
 permit icmp any any
 permit udp any any eq isakmp
 permit udp any any eq non500-isakmp
 permit esp any any
 permit ip 192.168.222.0 0.0.0.31 any
 permit ip 192.168.211.8 0.0.0.7 any
 permit ip 192.168.34.0 0.0.0.15 any
ip access-list extended NAT
 deny   ip 192.168.211.0 0.0.0.15 192.168.34.0 0.0.0.15
 deny   ip 192.168.211.0 0.0.0.7 192.168.211.8 0.0.0.7
 deny   ip 192.168.211.0 0.0.0.15 192.168.222.0 0.0.0.31
 permit ip 192.168.211.0 0.0.0.15 any
ip access-list extended VPN_1176
 permit ip 192.168.211.0 0.0.0.15 192.168.222.0 0.0.0.31
ip access-list extended VPN_340
 permit ip 192.168.211.0 0.0.0.15 192.168.34.0 0.0.0.15
control-plane
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 transport input ssh
end
debug output during failure:
*May 23 05:27:12.293: IKEv2-INTERNAL:New ikev2 sa request admitted
*May 23 05:27:12.293: IKEv2-INTERNAL:Incrementing incoming negotiating sa count by one
*May 23 05:27:12.293: IKEv2-PAK:Next payload: SA, version: 2.0 Exchange type: IKE_SA_INIT, flags: INITIATOR Message id: 0, length: 596
Payload contents:
 SA  Next payload: KE, reserved: 0x0, length: 244
  last proposal: 0x2, reserved: 0x0, length: 44
  Proposal: 1, Protocol id: IKE, SPI size: 0, #trans: 4    last transform: 0x3, reserved: 0x0: length: 12
    type: 1, reserved: 0x0, id: AES-CBC
    last transform: 0x3, reserved: 0x0: length: 8
    type: 3, reserved: 0x0, id: SHA96
    type: 2, reserved: 0x0, id: SHA1
    last transform: 0x0, reserved: 0x0: length: 8
    type: 4, reserved: 0x0, id: DH_GROUP_1536_MODP/Group 5
  last proposal: 0x0, reserved: 0x0, length: 196
  Proposal: 2, Protocol id: IKE, SPI size: 0, #trans: 22    last transform: 0x3, reserved: 0x0: length: 12
    type: 1, reserved: 0x0, id: 3DES
    type: 3, reserved: 0x0, id: SHA256
    type: 3, reserved: 0x0, id: SHA384
    type: 3, reserved: 0x0, id: SHA512
    type: 3, reserved: 0x0, id: AES XCBC 96
    type: 3, reserved: 0x0, id: MD596
    type: 2, reserved: 0x0, id: AES CBC
    type: 2, reserved: 0x0, id: SHA256
    type: 2, reserved: 0x0, id: SHA384
    type: 2, reserved: 0x0, id: SHA512
    type: 2, reserved: 0x0, id: MD5
    type: 4, reserved: 0x0, id: DH_GROUP_3072_MODP/Group 15
    type: 4, reserved: 0x0, id: DH_GROUP_4096_MODP/Group 16
    type: 4, reserved: 0x0, id: Unknown - 18
    type: 4, reserved: 0x0, id: DH_GROUP_2048_MODP/Group 14
    type: 4, reserved: 0x0, id: DH_GROUP_2048_256_MODP/Group 24
    type: 4, reserved: 0x0, id: DH_GROUP_1024_MODP/Group 2
 KE  Next payload: N, reserved: 0x0, length: 200
    DH group: 5, Reserved: 0x0
 N  Next payload: NOTIFY, reserved: 0x0, length: 36
*May 23 05:27:12.294: IKEv2-INTERNAL:Parse Notify Payload: NAT_DETECTION_SOURCE_IP NOTIFY(NAT_DETECTION_SOURCE_IP)  Next payload: NOTIFY, reserved: 0x0, length: 28
    Security protocol id: Unknown - 0, spi size: 0, type: NAT_DETECTION_SOURCE_IP
*May 23 05:27:12.294: IKEv2-INTERNAL:Parse Notify Payload: NAT_DETECTION_DESTINATION_IP NOTIFY(NAT_DETECTION_DESTINATION_IP)  Next payload: NOTIFY, reserved: 0x0, length: 28
    Security protocol id: Unknown - 0, spi size: 0, type: NAT_DETECTION_DESTINATION_IP
*May 23 05:27:12.294: IKEv2-INTERNAL:Parse Notify Payload: IKEV2_FRAGMENTATION_SUPPORTED NOTIFY(IKEV2_FRAGMENTATION_SUPPORTED)  Next payload: NOTIFY, reserved: 0x0, length: 8
    Security protocol id: Unknown - 0, spi size: 0, type: IKEV2_FRAGMENTATION_SUPPORTED
*May 23 05:27:12.294: IKEv2-INTERNAL:Parse Notify Payload: Unknown - 16431 NOTIFY(Unknown - 16431)  Next payload: NOTIFY, reserved: 0x0, length: 16
    Security protocol id: Unknown - 0, spi size: 0, type: Unknown - 0
*May 23 05:27:12.294: IKEv2-INTERNAL:Parse Notify Payload: REDIRECT_SUPPORTED NOTIFY(REDIRECT_SUPPORTED)  Next payload: NONE, reserved: 0x0, length: 8
    Security protocol id: Unknown - 0, spi size: 0, type: REDIRECT_SUPPORTED
*May 23 05:27:12.294: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: IDLE Event: EV_RECV_INIT
*May 23 05:27:12.294: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_INIT Event: EV_VERIFY_MSG
*May 23 05:27:12.294: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_INIT Event: EV_INSERT_SA
*May 23 05:27:12.294: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_INIT Event: EV_GET_IKE_POLICY
*May 23 05:27:12.294: IKEv2-INTERNAL:Adding Proposal aes256-sha1 to toolkit policy
*May 23 05:27:12.295: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_INIT Event: EV_PROC_MSG
*May 23 05:27:12.295: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_INIT Event: EV_DETECT_NAT
*May 23 05:27:12.295: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):Process NAT discovery notify
*May 23 05:27:12.295: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):Processing nat detect src notify
*May 23 05:27:12.295: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):Remote address matched
*May 23 05:27:12.295: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):Processing nat detect dst notify
*May 23 05:27:12.295: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):Local address matched
*May 23 05:27:12.295: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):No NAT found
*May 23 05:27:12.295: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_INIT Event: EV_CHK_CONFIG_MODE
*May 23 05:27:12.295: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_BLD_INIT Event: EV_SET_POLICY
*May 23 05:27:12.295: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):Setting configured policies
*May 23 05:27:12.295: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_BLD_INIT Event: EV_CHK_AUTH4PKI
*May 23 05:27:12.295: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_BLD_INIT Event: EV_PKI_SESH_OPEN
*May 23 05:27:12.295: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):Opening a PKI session
*May 23 05:27:12.295: CRYPTO_PKI: (9000F) Session started - identity not specified
*May 23 05:27:12.295: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_BLD_INIT Event: EV_GEN_DH_KEY
*May 23 05:27:12.304: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_BLD_INIT Event: EV_NO_EVENT
*May 23 05:27:12.304: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_BLD_INIT Event: EV_OK_RECD_DH_PUBKEY_RESP
*May 23 05:27:12.304: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):Action: Action_Null
*May 23 05:27:12.304: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_BLD_INIT Event: EV_GEN_DH_SECRET
*May 23 05:27:12.314: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_BLD_INIT Event: EV_NO_EVENT
*May 23 05:27:12.314: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_BLD_INIT Event: EV_OK_RECD_DH_SECRET_RESP
*May 23 05:27:12.314: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):Action: Action_Null
*May 23 05:27:12.314: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_BLD_INIT Event: EV_GEN_SKEYID
*May 23 05:27:12.314: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):Generate skeyid
*May 23 05:27:12.314: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_BLD_INIT Event: EV_GET_CONFIG_MODE
*May 23 05:27:12.314: IKEv2-INTERNAL:No config data to send to toolkit:
*May 23 05:27:12.314: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_BLD_INIT Event: EV_BLD_MSG
*May 23 05:27:12.314: IKEv2-INTERNAL:Construct Vendor Specific Payload: DELETE-REASON
*May 23 05:27:12.314: IKEv2-INTERNAL:Construct Vendor Specific Payload: (CUSTOM)
*May 23 05:27:12.314: IKEv2-INTERNAL:Construct Notify Payload: NAT_DETECTION_SOURCE_IP
*May 23 05:27:12.314: IKEv2-INTERNAL:Construct Notify Payload: NAT_DETECTION_DESTINATION_IP
*May 23 05:27:12.314: IKEv2-PAK:(SESSION ID = 6,SA ID = 2):Next payload: SA, version: 2.0 Exchange type: IKE_SA_INIT, flags: RESPONDER MSG-RESPONSE Message id: 0, length: 437
Payload contents:
 SA  Next payload: KE, reserved: 0x0, length: 48
  last proposal: 0x0, reserved: 0x0, length: 44
 N  Next payload: VID, reserved: 0x0, length: 36
 VID  Next payload: VID, reserved: 0x0, length: 23
 VID  Next payload: NOTIFY, reserved: 0x0, length: 21
 NOTIFY(NAT_DETECTION_DESTINATION_IP)  Next payload: CERTREQ, reserved: 0x0, length: 28
 CERTREQ  Next payload: NONE, reserved: 0x0, length: 25
    Cert encoding X.509 Certificate - signature
*May 23 05:27:12.315: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: INIT_DONE Event: EV_DONE
*May 23 05:27:12.315: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: INIT_DONE Event: EV_CHK4_ROLE
*May 23 05:27:12.315: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: INIT_DONE Event: EV_START_TMR
*May 23 05:27:12.315: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 0 CurState: R_WAIT_AUTH Event: EV_NO_EVENT
*May 23 05:27:12.485: IKEv2-INTERNAL:Got a packet from dispatcher
*May 23 05:27:12.485: IKEv2-INTERNAL:Processing an item off the pak queue
*May 23 05:27:12.485: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):Request has mess_id 1; expected 1 through 1
*May 23 05:27:12.485: IKEv2-PAK:(SESSION ID = 6,SA ID = 2):Next payload: ENCR, version: 2.0 Exchange type: IKE_AUTH, flags: INITIATOR Message id: 1, length: 1324
Payload contents:
 IDi  Next payload: CERT, reserved: 0x0, length: 67
    Id type: DER ASN1 DN, Reserved: 0x0 0x0
 CERT  Next payload: CERTREQ, reserved: 0x0, length: 771
 CERTREQ  Next payload: IDr, reserved: 0x0, length: 25
 IDr  Next payload: AUTH, reserved: 0x0, length: 34
 AUTH  Next payload: SA, reserved: 0x0, length: 264
    Auth method RSA, reserved: 0x0, reserved 0x0
 SA  Next payload: TSi, reserved: 0x0, length: 44
  last proposal: 0x0, reserved: 0x0, length: 40
  Proposal: 1, Protocol id: ESP, SPI size: 4, #trans: 3    last transform: 0x3, reserved: 0x0: length: 12
    type: 5, reserved: 0x0, id: Don't use ESN
 TSi  Next payload: TSr, reserved: 0x0, length: 24
    Num of TSs: 1, reserved 0x0, reserved 0x0
    TS type: TS_IPV4_ADDR_RANGE, proto id: 0, length: 16
    start port: 0, end port: 65535
    start addr: 192.168.34.0, end addr: 192.168.34.15
 TSr  Next payload: NOTIFY, reserved: 0x0, length: 24
    start addr: 192.168.211.0, end addr: 192.168.211.15
*May 23 05:27:12.486: IKEv2-INTERNAL:Parse Notify Payload: Unknown - 16417 NOTIFY(Unknown - 16417)  Next payload: NONE, reserved: 0x0, length: 8
*May 23 05:27:12.486: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 1 CurState: R_WAIT_AUTH Event: EV_RECV_AUTH
*May 23 05:27:12.486: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 1 CurState: R_WAIT_AUTH Event: EV_CHK_NAT_T
*May 23 05:27:12.486: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 1 CurState: R_WAIT_AUTH Event: EV_PROC_ID
*May 23 05:27:12.486: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):Received valid parameteres in process id
*May 23 05:27:12.491: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 1 CurState: AUTH_DONE Event: EV_FAIL
*May 23 05:27:12.491: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 1 CurState: EXIT Event: EV_ABORT
*May 23 05:27:12.491: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 1 CurState: EXIT Event: EV_CHK_PENDING_ABORT
*May 23 05:27:12.491: IKEv2-INTERNAL:Negotiating SA request deleted
*May 23 05:27:12.491: IKEv2-INTERNAL:Decrement count for incoming negotiating
*May 23 05:27:12.492: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 1 CurState: EXIT Event: EV_CHK_GKM
*May 23 05:27:12.492: IKEv2-INTERNAL:(SESSION ID = 6,SA ID = 2):SM Trace-> SA: I_SPI=0E4072C2DD4A6542 R_SPI=7F99B96F1A6D2949 (R) MsgID = 1 CurState: EXIT Event: EV_UPDATE_CAC_STATS
*May 23 05:27:12.492: CRYPTO_PKI: Rcvd request to end PKI session 9000F.
*May 23 05:27:12.492: CRYPTO_PKI: PKI session 9000F has ended. Freeing all resources.
*May 23 05:27:14.201: [] -> [ACL VPN_340]: message ACL notify RP
*May 23 05:27:14.201: [ACL VPN_340]: message = ACL notify RP
*May 23 05:27:14.201: [ACL VPN_340]: state = ACL notify RP action
*May 23 05:27:14.201: IPSEC:(SESSION ID = 1) (MESSAGE) crypto_ipsec_construct_sa_request request already in progress
*May 23 05:27:15.477: IKEv2-INTERNAL:Got a packet from dispatcher
*May 23 05:27:15.478: IKEv2-INTERNAL:Processing an item off the pak queue
*May 23 05:27:15.480: IKEv2-INTERNAL:Couldn't find matching SA
*May 23 05:27:15.480: IKEv2-PAK:(SESSION ID = 0,SA ID = 0):Next payload: ENCR, version: 2.0 Exchange type: INFORMATIONAL, flags: RESPONDER Message id: 0, length: 76
*May 23 05:27:16.487: IKEv2-INTERNAL:Got a packet from dispatcher
*May 23 05:27:16.488: IKEv2-INTERNAL:Processing an item off the pak queue
*May 23 05:27:16.490: IKEv2-INTERNAL:Couldn't find matching SA
*May 23 05:27:16.490: IKEv2-PAK:(SESSION ID = 0,SA ID = 0):Next payload: ENCR, version: 2.0 Exchange type: IKE_AUTH, flags: INITIATOR Message id: 1, length: 1324
This log output, besides being horrendously unreadable, shows no useful information as to why the tunnel is failing. In fact, the only failure I see is the line "CurState: AUTH_DONE Event: EV_FAIL", which tells me nothing as to why it failed.
What is going on here?
7 Replies 7
assuming that you are running router firmware version 1.0.02.16 (which was released in January, and which is the first to support ikev2), and that obviously the encryption, decryption, and authentication parameters on the RV340 match what you have configured on the ISR, you might want to try a second policy, separate from the policy for the ASA, and use the parameters outlined in the document below:
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/Configuring_IKEv2_on_the_RV34x_Series_Router.html
I am actually running the newest firmware on the RV340 (1.0.03.15). Are you saying that I specifically need to use those encr/hash/DH settings in that document? Or are you just providing that for reference? I can assure you that all settings are duplicated on the RV340 (with obvious mirroring of the subnets on each side).
And when you say "second policy", do you mean a second profile? As in, "crypto ikev2 profile RV340W"? I am intending to use the same policy & proposal for both the ASA and the RV340..... surely this can be done?
Also, when I try to create a new "crypto ikev2 profile" for the RV340, I find that I am also not allowed to use the same certmap.... I would have to duplicate the certmap already in use and name it "CERTMAP2", or something. That doesn't seem right..... All devices are using certs signed by the same CA.
Hello train_wreck,
From the log messages of your first post we see:
that there are NAT issues.
Is the RV340 router behind NAT ?
Edit:
your firmware version on RV340 is newer so you should be fine. I don't think you need to downgrade.
About the document provided by Georg.
It may be wise to implement a second IKEv2 profile dedicated to the RV340 and the use of the Phase I and Phase II IKE options reported in the document as to be seen as something tested and validated for interoperability by Cisco.
IF you need to build a second certmap you should give it a try.
Hope to help
Giuseppe
No, it is not. Both WAN IPs of both devices are within the same /29 (e.g., the ISR is at 50.x.x.3/29 and the RV340 is at 50.x.x.4/29) and are connected to the same VLAN on the same switch.
Also, I tried adding a second ikev2 profile, with a second certmap and a second ipsec profile linked to the ikev2 profile. This changed nothing. The problem is still there, and the error is still the same ("EV_FAIL").
I have narrowed this down to a problem with the RV340 router. I have since added 2 more additional crypto map sites to different devices (a Fortigate 30E and a ZyXel USG40), and both work flawlessly, in addition to the original ASA that has remained working the whole time. Only the RV340 has this problem. All devices use certificates that were signed with my internal CA.
My original configuration was mostly correct; I did not have to use IPsec profiles or multiple IKEv2 profiles to accomplish this, and in fact because I was using crypto maps, the ipsec profile was unnecessary. Only 1 IKEv2 profile is used in multiple crypto map entries, and all are configured the same and are working fine (except the RV340).
This will not be the first problem I have had with the RV340, VPN-related or otherwise. Cisco really needs to get out of the "Small Business" VPN router business, it's obvious they don't really care about it.
ZBFW does not inspect ESP, you need to change the policy-map  to "pass".
pass
