ISR4321 ROUTER IMAGE LOADING ISSUE
Sreejesh S
Hi Team
after initializing IOS up-gradation facing challenge on boot  with below error
Initializing Hardware ...
Checking for PCIe device presence...done
System integrity status: 0x610
Rom image verified correctly
System Bootstrap, Version 16.7(3r), RELEASE SOFTWARE
Copyright (c) 1994-2017 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
ISR4321/K9 platform with 4194304 Kbytes of main memory
Device not found flash:
autoboot: boot failed, restarting...
Resetting .......
Resetting .......
Resetting .......
Resetting .......
Resetting .......
Resetting .......
Resetting .......
Resetting .......
Resetting .......
Illegal IP address
The following variables are REQUIRED for tftp
IP_ADDRESS: The IP address for this unit
IP_SUBNET_MASK: The subnet mask for this unit
DEFAULT_GATEWAY: The default gateway for this unit
TFTP_SERVER: The IP address of the server to fetch from
TFTP_FILE: The filename to fetch
Resetting .......
Illegal IP address
Resetting .......
can any one help to fix this
6 Replies 6
Francesco Molino
You might face an existing bug, so you need to go into ROMmon to restart it:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg37458/?rfs=iqvred
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
balaji.bandi
Can get on to ROMMON
> dir bootflash:
if you have image on USB boot from USB and test it.
https://www.cisco.com/c/en/us/support/docs/routers/4000-series-integrated-services-routers/200678-Troubleshoot-Cisco-4000-Series-ISR-Stuck.html
BB
Leo Laohoo
Boot variable string is incorrect.
Force the router to go into ROMMON and post the complete output to the command "dir flash:".
CSCvg37458
EDIT:  Corrected the link to the Bug ID.
Leo Laohoo
By the way, @Sreejesh S.
What version is the router set to boot?
I want to load with isr4300-universalk9.16.07.01.SPA.bin
sree
16.7.1 is a single-release version that came out on November 2017 -- That's four and a half years ago.
Is there a particular feature you are looking for in 16.7.X?
If not, use the latest 16.6.9 because it tends to be more stable than the others.
16.9.X introduces the infernal feature Cisco Smart License and is a PITA.
Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode)
