ISR4331 config save issue
Hello everyone, I have issue while backuping configuration from ISR4331 router from web interface
if I choose HTTP method nothing happens
if I choose TFTP, SFTP, or FTP there is error
balaji.bandi
what is the version of code running,
have you tried manually from cli and see if that works. for the TFTP, SFTP, or FTP there is error  - this confirms there is no far end issue of TFTP ?
follow below guide :
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/software/configuration/guide/isr4400swcfg/Configuration___Examples.html?bookSearch=true#concept_13B5AEFF93FF422BBDA1039021CC8B70
Also if you have different route, use right source interface as source to reach tftp need to be con figured.
example :
ip tftp source-interface <PORT or VLAN>
BB
how about web http saving?
