ISR4331 No valid BOOT image found after inserting flash
Patrick McHenry
Level 4
Level 4
Hey,
Just installed new flash card and new RAM in 4331 router and there is no image to boot.
Before I installed the new flash there was an image and it booted fine....must I install an image to the new flash before it will boot?
Thank you
Output after installing new flash:
Initializing Hardware ...
System integrity status: 00000610
Rom image verified correctly
System Bootstrap, Version 15.4(3r)S3, RELEASE SOFTWARE
Copyright (c) 1994-2014  by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: PowerOn
Cisco ISR4331/K9 platform with 16777216 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
boot: cannot determine first file name on device "bootflash:/"
autoboot: boot failed, restarting...
Last reset cause: LocalSoft
rommon 1 >
Leo Laohoo
Those routers should have Compact Flash.  And they always come with one.  So if you can't boot into the IOS maybe someone's playing a trick on you and removed the CF.
