3850 replace 3560 for BGP
jmecklenburg
Level 2
Level 2
I have a Cisco 3560 as core in a small office, this site, get a default route to main site from EIGRP, and the main site have a BGP to connect with all sites.
For a change in a topology we need recibe all the BGP table redistribute from EIGRP and the 3560 can't handle all the routes. A Cisco 3850 it's ok for this topology?
fixie rider
9 Replies 9
Leo Laohoo
3850 has 2 Gb of flash and I don't believe this is adequate enough to hold and store the complete BGP routing table.
But for BGP operation the routing table is storage in a DRAM not in flash a 3850 have 4G in a DRAM for the 48 ports model.
fixie rider
How many bgp routes are you looking at?
John
**Please rate posts you find helpful**
The show ip route summary in the main site show the following
IP routing table name is default (0x0)
IP routing table maximum-paths is 8
Route Source    Networks    Subnets     Replicates  Overhead    Memory (bytes)
connected       0           31          0           1860        5580
static          2           10          0           720         2160
eigrp 1         0           0           0           0           0
bgp 65056       30          459         0           29340       88020
  External: 487 Internal: 0 Local: 2
eigrp 25        0           10          0           840         1800
internal        29                                              27500
Total           61          510         0           32760       125060
fixie rider
Any idea?
Please help.
fixie rider
If you are looking for complete internet routing table then currently it is approx 550k.
Now as per Cisco datasheet of 3850 - its supports only 24k which includes Total number of IPv4 routes (ARP plus learned routes).
So anyway it is (3850) not a good choice if not doing any kind of route aggregation or default routing at/to main site. Other wise you need to look for high end models with SUP2T etc.
Vivek
it's not a full internet routing table, it's a internal WAN, just 30 network and 500 subnet aprox 88K as can see in the main site.
fixie rider
For 30 network and 500 subnet , 3850 is more than enough.
Posts in this discussion have been modified  due to possible misconduct. Please refer to the CSC terms of use for more details. https://supportforums.cisco.com/document/29951/cisco-support-community-acceptable-use-agreement
