02-12-2012 10:13 AM - edited 03-04-2019 03:14 PM
Hi everyone.
I've set up home lab. I have two routers 1721, 1 switch 2950, PC and 2 laptops.
My two routers are connected via serial interface. R2 is directly connected to the PC on FastE 0 192.168.1.2. PC addres 192.168.1.1
Serial int addres 192.168.1.65.
R1 [serial int 192.168.1.66 connected to R2] with FastE 192.168.1.129 is connected to the switch [vlan int 192.168.1.130].
Two laptops are connected to the switch on ports 1 and 2. [192.168.1.131 - 192.168.1.133]
The problem I'm having is that I can't ping devices on the other subnets. I have static routing set up on both routers:
R1-
Gateway of last resort is not set
192.168.1.0/24 is variably subnetted, 4 subnets, 2 masks
C 192.168.1.65/32 is directly connected, Serial0
C 192.168.1.64/26 is directly connected, Serial0
S 192.168.1.0/26 [1/0] via 192.168.1.65
C 192.168.1.128/26 is directly connected, FastEthernet0
R2-
C 192.168.1.66/32 is directly connected, Serial0
C 192.168.1.0/26 is directly connected, FastEthernet0
S 192.168.1.128/26 [1/0] via 192.168.1.66
The thing when I'm on R2 I'm able to ping R1, switch and laptops - also my PC.
When I'm on R1 it is the same.
BUT. Whan I'm trying to ping something behind the router while on PC or laptops I'm getting this message:
----Reply from x.x.x.x: Destination host unreachable. - Packets sent=4 , received 4, lost 0---
Also replying address is different from the one I'm pinging.
I have no idea what is going on.
While setting it I was using Packet Tracer as a guide and created exact clone of this network - and a PT net works fine.
I did disable firewalls.
I'm attaching PT file.
Please help !!!
R1 config file:
Current configuration : 890 bytes
version 12.4
service password-encryption
hostname Router-1
boot-start-marker
boot-end-marker
enable secret 5 $1$q0Qj$8hrfpMXpSj4Xr96xFAhyM0
no aaa new-model
ip cef
archive
log config
hidekeys
interface FastEthernet0
ip address 192.168.1.129 255.255.255.192
speed auto
interface Serial0
ip address 192.168.1.66 255.255.255.192
encapsulation ppp
no fair-queue
ip forward-protocol nd
ip route 192.168.1.0 255.255.255.192 192.168.1.65
no ip http server
no ip http secure-server
control-plane
banner motd ^C
Router-1!!!!!!!!!!
^C
line con 0
password 7 0202114B0A
logging synchronous
login
line aux 0
line vty 0 4
password 7 1413071B0D
logging synchronous
login
end
R2 config file.
Current configuration : 968 bytes
version 12.4
hostname Router-2
boot-start-marker
boot-end-marker
enable secret 5 $1$H2IG$EsBXfuVE3BbB96tJWpoBF1
no aaa new-model
ip cef
archive
log config
hidekeys
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
ip address 192.168.1.2 255.255.255.192
speed auto
interface Serial0
ip address 192.168.1.65 255.255.255.192
encapsulation ppp
no fair-queue
clock rate 2000000
ip route 192.168.1.128 255.255.255.192 192.168.1.66
no ip http server
control-plane
banner motd ^C
Router-2!!!!!!
^C
line con 0
password 7 045F1E160E
logging synchronous
login
line aux 0
line vty 0 4
password 7 130102020A
login
end
Solved! Go to Solution.
02-18-2012 11:05 AM
Hi guys
So i decided I will rebuild the whole thing from the begining.
All the addresses and the layout is the same.
I was trying to narrow possible causes - so let me start from here.
When on the Router 2 I can ping Routers 1 both interfaces [ .66 and .129]
but
when on Router 1 I can only ping serial interface of Router2 [.65]
I'm attaching debug below. I need to sort that out!!! Please help me.
Thanks.
Success rate is 100 percent (5/5), round-trip min/avg/max = 36/37/40 ms
Router---1#
*Mar 1 06:30:54.511: IP: tableid=0, s=192.168.1.66 (local), d=192.168.1.65 (Serial0), routed via FIB
*Mar 1 06:30:54.511: IP: s=192.168.1.66 (local), d=192.168.1.65 (Serial0), len 100, sending
*Mar 1 06:30:54.547: IP: tableid=0, s=192.168.1.65 (Serial0), d=192.168.1.66 (Serial0), routed via RIB
*Mar 1 06:30:54.547: IP: s=192.168.1.65 (Serial0), d=192.168.1.66 (Serial0), len 100, rcvd 3
*Mar 1 06:30:54.547: IP: tableid=0, s=192.168.1.66 (local), d=192.168.1.65 (Serial0), routed via FIB
*Mar 1 06:30:54.551: IP: s=192.168.1.66 (local), d=192.168.1.65 (Serial0), len 100, sending
*Mar 1 06:30:54.583: IP: tableid=0, s=192.168.1.65 (Serial0), d=192.168.1.66 (Serial0), routed via RIB
*Mar 1 06:30:54.583: IP: s=192.168.1.65 (Serial0), d=192.168.1.66 (Serial0), len 100, rcvd 3
*Mar 1 06:30:54.587: IP: tableid=0, s=192.168.1.66 (local), d=192.168.1.65 (Serial0), routed via FIB
*Mar 1 06:30:54.587: IP: s=192.168.1.66 (local), d=192.168.1.65 (Serial0), len 100, sending
*Mar
Router---1#1 06:30:54.623: IP: tableid=0, s=192.168.1.65 (Serial0), d=192.168.1.66 (Serial0), routed via RIB
*Mar 1 06:30:54.623: IP: s=192.168.1.65 (Serial0), d=192.168.1.66 (Serial0), len 100, rcvd 3
*Mar 1 06:30:54.623: IP: tableid=0, s=192.168.1.66 (local), d=192.168.1.65 (Serial0), routed via FIB
*Mar 1 06:30:54.623: IP: s=192.168.1.66 (local), d=192.168.1.65 (Serial0), len 100, sending
*Mar 1 06:30:54.659: IP: tableid=0, s=192.168.1.65 (Serial0), d=192.168.1.66 (Serial0), routed via RIB
*Mar 1 06:30:54.659: IP: s=192.168.1.65 (Serial0), d=192.168.1.66 (Serial0), len 100, rcvd 3
*Mar 1 06:30:54.663: IP: tableid=0, s=192.168.1.66 (local), d=192.168.1.65 (Serial0), routed via FIB
*Mar 1 06:30:54.663: IP: s=192.168.1.66 (local), d=192.168.1.65 (Serial0), len 100, sending
*Mar 1 06:30:54.695: IP: tableid=0, s=192.168.1.65 (Serial0), d=192.168.1.66 (Serial0), routed via RIB
*Mar 1 06:30:54.695: IP: s=192.168.1.65 (Serial0), d=192.168.1.66 (Serial0), len 100, rcvd 3
Router---1#
Router---1#ping 192.168.1.2
Sending 5, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
*Mar 1 06:31:19.271: IP: s=192.168.1.66 (local), d=192.168.1.2, len 100, unroutable.
*Mar 1 06:31:21.271: IP: s=192.168.1.66 (local), d=192.168.1.2, len 100, unroutable.
*Mar 1 06:31:23.271: IP: s=192.168.1.66 (local), d=192.168.1.2, len 100, unroutable.
*Mar 1 06:31:25.271: IP: s=192.168.1.66 (local), d=192.168.1.2, len 100, unroutable.
*Mar 1 06:31:27.271: IP: s=192.168.1.66 (local), d=192.168.1.2, len 100, unroutable.
Success rate is 0 percent (0/5)
02-18-2012 01:17 PM
can you change PPP encapsulation to hdlc with no encap ppp command and do it again.
also if it's not working can you do ping 192.168.1.2 source f0/0 and post the output of the debug.
Regards.
Alain
02-19-2012 12:02 PM
I know I'm being pain in the a.s but because of that i can't sleep. I was going to take CCENT exam soon but now I'm realy in doubt.
I did what you suggested and I've chaned encapsulation to HDLC and I was able to ping interface on the other side - BUT only when I was on the router.
When I was trying to ping it from my laptops I couldn't. So I understand that they are routing but not all the traffic???
I'm going mad here.
I removed all the static routing and if you guys could guide me through it - I'm probably doing some stupid mistake when setting this up.
So there is no routing entries and the routing tables are looking like that:
Router1
192.168.1.0/24 is variably subnetted, 3 subnets, 2 masks
Router 2
Routers are able to reach theirs serial interfaces.
PC on the 192.168.1.0 network can ping .2 interface but I can't ping .65 interface - it says : Dest Host unreachable. BUT I'm able to get .66 interface of Router1.
From the laptops on the 192.168.128 network I can ping .129 interface of Router1 AND its serial interface .66 BUT not .65
What kind of black magic is this????
I'm starting to think that there is something wrong with my hardware.
02-19-2012 12:07 PM
Ok, you are driving me a little mad too. Let's go with the shotgun approach since precise routing doesn't seem to be working.
On R1:
config t
ip route 0.0.0.0 0.0.0.0 192.168.1.66
On R2:
config t:
ip route 0.0.0.0 0.0.0.0 192.168.1.65
That configures each router to be the other router for its default gateway which will enable full routing between all connected interfaces in this topology. If after those routes go in you still can't ping anything connected from any source interface on either router, then it has to be hardware or something stranger going on and you need to call in a consultant to show you.
02-19-2012 12:47 PM
Thats what I'm getting
R1
Router---1(config)#ip route 0.0.0.0 0.0.0.0 192.168.1.66
%Invalid next hop address (it's this router)
R2
Router---2(config)#ip route 0.0.0.0 0.0.0.0 192.168.1.65
I think you meant R1 .65 and R2 .66 - i did that.
Routing tables:
R1
Gateway of last resort is 192.168.1.65 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.1.65
R2
Gateway of last resort is 192.168.1.66 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.1.66
When I'm on routers i can ping every single address on any network:
Router1
Router---1#ping 192.168.1.131
Sending 5, 100-byte ICMP Echos to 192.168.1.131, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Router---1#ping 192.168.1.133
Sending 5, 100-byte ICMP Echos to 192.168.1.133, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Router---1#ping 192.168.1.130
Sending 5, 100-byte ICMP Echos to 192.168.1.130, timeout is 2 seconds:
Router---1#ping 192.168.1.129
Sending 5, 100-byte ICMP Echos to 192.168.1.129, timeout is 2 seconds:
Router---1#ping 192.168.1.66
Sending 5, 100-byte ICMP Echos to 192.168.1.66, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 64/65/68 ms
Router---1#ping 192.168.1.65
Sending 5, 100-byte ICMP Echos to 192.168.1.65, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/33/36 ms
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/32/36 ms
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Router2
Router---2#ping 192.168.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/4 ms
Router---2#ping 192.168.1.2
Router---2#ping 192.168.1.65
Success rate is 100 percent (5/5), round-trip min/avg/max = 72/80/108 ms
Router---2#ping 192.168.1.66
Success rate is 100 percent (5/5), round-trip min/avg/max = 40/45/68 ms
Router---2#ping 192.168.1.129
Success rate is 100 percent (5/5), round-trip min/avg/max = 40/44/64 ms
Router---2#ping 192.168.1.130
Router---2#ping 192.168.1.131
Router---2#ping 192.168.1.133
So that works!
But when pinging from the PC or a laptop:
Replay from 192.168.1.64: Destination Host unreachable
02-19-2012 12:53 PM
I thought this was a crossover T1 with both routers in the same room - those ping times are pretty high if that is the case.
Do the same tests, but source the ping from the Ethernet interface on the router, i.e.:
ping 192.168.1.129 source 192.168.1.1
02-19-2012 01:00 PM
OK
Router 1
Router---1#ping 192.168.1.1 source 192.168.1.129
Packet sent with a source address of 192.168.1.129
Router---1#ping 192.168.1.2 source 192.168.1.129
Router 2
Router---2#ping 192.168.1.129 source 192.168.1.2
Packet sent with a source address of 192.168.1.2
Router---2#ping 192.168.1.133 source 192.168.1.2
02-19-2012 01:03 PM
Routing is good, you have a PC issue or some crazy filtering going on that I am not seeing.
02-19-2012 01:07 PM
Hello
1. Test "ping" from hosts behind the routers.
2. Post the output of "debug ip routing" and "debug ip packet detail" on the routers
Toshi
02-19-2012 01:16 PM
OK
I've run that on the Router 2:
Router---2#debug ip packet detail
IP packet debugging is on (detailed)
Now I'm generating traffic (pinging laptop .133 on the other side) but i can't see any outcome on the router.
How do I do that?
Thanks.
02-19-2012 01:20 PM
Hello
Just run it on R1. Traffic gernerated on hosts behind R1.
Toshi
02-19-2012 03:11 PM
WOW.
I took an hour brake. Came back and typed the command
Router---1#debug ip routing
IP routing debugging is on
Router---2#debug ip routing
Now when I'm pinging from the .133 laptop i can reach .1 PC !!!
The output I'm getting from the Router 1:
Router---1#
*Mar 1 10:34:21.279: RT: NET-RED 0.0.0.0/0
These messages are showing every 1 minute.
*Mar 1 10:36:21.279: RT: NET-RED 0.0.0.0/0
Router---1#
*Mar 1 10:37:21.279: RT: NET-RED 0.0.0.0/0
Router---1#
*Mar 1 10:38:21.279: RT: NET-RED 0.0.0.0/0
There is nothing showing on Router 2 and still cant ping .133 host from .1
What have i done that now i'm able to ping from .133 - typing debug command was all i did???
02-19-2012 01:07 PM
Thanks a lot.
Have you got any idea what may causing this?
I have all firewalls disabled.
Maybe it's the switch that is doing something odd - i'm just guessing here.
02-19-2012 03:09 PM
Do you have both routers and all end devices plugged into one switch?
If yes, I would connect PC directly to one router with a cross-over cable and test again
Eugen
02-19-2012 03:14 PM
Thats is exactly how i got this set up.
There is a PPT file attached to my post #1 on the top of this page - so you can see it clearly.
