Issue with routing?!? I know I'm missing something.
osatronix
Hi everyone.
I've set up home lab. I have two routers 1721, 1 switch 2950, PC and 2 laptops.
My two routers are connected via serial interface. R2 is directly connected to the PC on FastE 0 192.168.1.2.   PC addres 192.168.1.1
Serial int addres 192.168.1.65.
R1 [serial int 192.168.1.66 connected to R2] with FastE 192.168.1.129 is connected to the switch [vlan int 192.168.1.130].
Two laptops are connected to the switch on ports 1 and 2. [192.168.1.131  -  192.168.1.133]
The problem I'm having is that I can't ping devices on the other subnets. I have static routing set up on both routers:
R1-
Gateway of last resort is not set
     192.168.1.0/24 is variably subnetted, 4 subnets, 2 masks
C       192.168.1.65/32 is directly connected, Serial0
C       192.168.1.64/26 is directly connected, Serial0
S       192.168.1.0/26 [1/0] via 192.168.1.65
C       192.168.1.128/26 is directly connected, FastEthernet0
R2-
C       192.168.1.66/32 is directly connected, Serial0
C       192.168.1.0/26 is directly connected, FastEthernet0
S       192.168.1.128/26 [1/0] via 192.168.1.66
The thing when I'm on R2 I'm able to ping R1, switch and laptops - also my PC.
When I'm on R1 it is the same.
BUT. Whan I'm trying to ping something behind the router while on PC or laptops I'm getting this message:
----Reply from x.x.x.x: Destination host unreachable.  -  Packets sent=4 , received 4, lost 0---
Also replying address is different from the one I'm pinging.
I have no idea what is going on.
While setting it I was using Packet Tracer as a guide and created exact clone of this network - and a PT net works fine.
I did  disable firewalls.
I'm attaching PT file.
Please help !!!
R1 config file:
Current configuration : 890 bytes
version 12.4
service password-encryption
hostname Router-1
boot-start-marker
boot-end-marker
enable secret 5 $1$q0Qj$8hrfpMXpSj4Xr96xFAhyM0
no aaa new-model
ip cef
archive
log config
  hidekeys
interface FastEthernet0
ip address 192.168.1.129 255.255.255.192
speed auto
interface Serial0
ip address 192.168.1.66 255.255.255.192
encapsulation ppp
no fair-queue
ip forward-protocol nd
ip route 192.168.1.0 255.255.255.192 192.168.1.65
no ip http server
no ip http secure-server
control-plane
banner motd ^C
Router-1!!!!!!!!!!
^C
line con 0
password 7 0202114B0A
logging synchronous
login
line aux 0
line vty 0 4
password 7 1413071B0D
logging synchronous
login
end
R2 config file.
Current configuration : 968 bytes
version 12.4
hostname Router-2
boot-start-marker
boot-end-marker
enable secret 5 $1$H2IG$EsBXfuVE3BbB96tJWpoBF1
no aaa new-model
ip cef
archive
log config
  hidekeys
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
ip address 192.168.1.2 255.255.255.192
speed auto
interface Serial0
ip address 192.168.1.65 255.255.255.192
encapsulation ppp
no fair-queue
clock rate 2000000
ip route 192.168.1.128 255.255.255.192 192.168.1.66
no ip http server
control-plane
banner motd ^C
Router-2!!!!!!
^C
line con 0
password 7 045F1E160E
logging synchronous
login
line aux 0
line vty 0 4
password 7 130102020A
login
end
38 Replies 38
Just a small suggestion.
If I have the same type of problems you are experiencing I normally set up a sniffer (wireshark) so that I can know if the packets hit the target or not. regardless of firewall or not.
If you have ethernet between the routers (I think I saw somewhere that you were using serial links then this does not apply) you can connect a switch inbetween the routers and mirror a port to sniff the traffic there, then you can track down the problems much faster.
Good luck
Strange. It looks ok on PT.
Can you post the output of "sh controllers serial 0" and "sh int s0" of both routers?
Yeah I know thats something really odd is going on.
I will post it tomorrow cause now i need to go to bed - I'm working in the morning.
Thanks all for your responses.
I'll be back tomorrow.
Once again thanks.
Good night.
R1
Router---1#show controllers serial 0
Interface Serial0
Hardware is PowerQUICC MPC860
DTE V.35 TX and RX clocks detected.
idb at 0x832E391C, driver data structure at 0x832EB028
SCC Registers:
General [GSMR]=0x2:0x00000030, Protocol-specific [PSMR]=0x8
Events [SCCE]=0x0000, Mask [SCCM]=0x001F, Status [SCCS]=0x06
Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E
Interrupt Registers:
Config [CICR]=0x00365F80, Pending [CIPR]=0x00008000
Mask   [CIMR]=0x40204000, In-srv  [CISR]=0x00000000
Command register [CR]=0x600
Port A [PADIR]=0x0000, [PAPAR]=0x0903
       [PAODR]=0x0000, [PADAT]=0xFFFD
Port B [PBDIR]=0x0180F, [PBPAR]=0x0E00E
       [PBODR]=0x00000, [PBDAT]=0x0057C
Port C [PCDIR]=0x000, [PCPAR]=0x000
       [PCSO]=0x020,  [PCDAT]=0xFCC, [PCINT]=0x000
Receive Ring
        rmd(FF003030): status 9000 length 12 address 720FDE4
        rmd(FF003038): status 9000 length 12 address 7210464
        rmd(FF003040): status 9000 length 12 address 7210AE4
        rmd(FF003048): status 9000 length 12 address 7211164
        rmd(FF003050): status 9000 length 12 address 72117E4
        rmd(FF003058): status 9000 length 12 address 7211E64
        rmd(FF003060): status 9000 length 34 address 7212B64
        rmd(FF003068): status 9000 length 2E address 72131E4
        rmd(FF003070): status 9000 length 2E address 7213864
        rmd(FF003078): status 9000 length 12 address 7213EE4
        rmd(FF003080): status 9000 length 12 address 720D6E4
        rmd(FF003088): status 9000 length 12 address 720F764
        rmd(FF003090): status 9000 length 12 address 720DD64
        rmd(FF003098): status 9000 length 12 address 720E3E4
        rmd(FF0030A0): status 9000 length 12 address 720EA64
        rmd(FF0030A8): status B000 length 153 address 720F0E4
Transmit Ring
        tmd(FF0030B0): status 5C00 length 2C address 721C3F4
        tmd(FF0030B8): status 5C00 length 10 address 720D6E4
        tmd(FF0030C0): status 5C00 length 10 address 70CFA14
        tmd(FF0030C8): status 5C00 length 10 address 720DD64
        tmd(FF0030D0): status 5C00 length 10 address 70CFC94
        tmd(FF0030D8): status 5C00 length 10 address 720EA64
        tmd(FF0030E0): status 5C00 length 10 address 70D0054
        tmd(FF0030E8): status 5C00 length 10 address 7210464
        tmd(FF0030F0): status 5C00 length 10 address 70D02D4
        tmd(FF0030F8): status 5C00 length 151 address 72307B4
        tmd(FF003100): status 5C00 length 10 address 7211164
        tmd(FF003108): status 5C00 length 10 address 70D0694
        tmd(FF003110): status 5C00 length 10 address 7211E64
        tmd(FF003118): status 5C00 length 10 address 70D07D4
        tmd(FF003120): status 5C00 length 10 address 7212B64
        tmd(FF003128): status 7C00 length 10 address 70D0914
tx_limited=0(16)
SCC GENERAL PARAMETER RAM (at 0xFF003C00)
Rx BD Base [RBASE]=0x3030, Fn Code [RFCR]=0x18
Tx BD Base [TBASE]=0x30B0, Fn Code [TFCR]=0x18
Max Rx Buff Len [MRBLR]=1548
Rx State [RSTATE]=0x18008440, BD Ptr [RBPTR]=0x3070
Tx State [TSTATE]=0x18000548, BD Ptr [TBPTR]=0x30B0
SCC HDLC PARAMETER RAM (at 0xFF003C38)
CRC Preset [C_PRES]=0xFFFF, Mask [C_MASK]=0xF0B8
Errors: CRC [CRCEC]=0, Aborts [ABTSC]=0, Discards [DISFC]=0
Nonmatch Addr Cntr [NMARC]=0
Retry Count [RETRC]=0
Max Frame Length [MFLR]=1610
Rx Int Threshold [RFTHR]=0, Frame Cnt [RFCNT]=65352
User-defined Address 0000/0000/0000/0000
User-defined Address Mask 0x0000
buffer size 1524
PowerQUICC SCC specific errors:
0 input aborts on receiving flag sequence
0 throttles, 0 enables
0 overruns
0 transmitter underruns
0 transmitter CTS losts
Router---1#sh int serial 0
Serial0 is up, line protocol is up
  Hardware is PowerQUICC Serial
  Internet address is 192.168.1.66/26
  MTU 1500 bytes, BW 1544 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, LCP Open
  Open: IPCP, CDPCP, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:10:28
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     207 packets input, 9583 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     1 input errors, 0 CRC, 1 frame, 0 overrun, 0 ignored, 0 abort
     232 packets output, 10702 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     1 unknown protocol drops
     0 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
R2
Router---2#show controllers serial 0
Interface Serial0
DCE V.35, clock rate 56000
idb at 0x832475C0, driver data structure at 0x8324ECCC
SCC Registers:
Config [CICR]=0x00365F80, Pending [CIPR]=0x00000804
Mask   [CIMR]=0x68200400, In-srv  [CISR]=0x00000000
Command register [CR]=0x640
Port A [PADIR]=0x1500, [PAPAR]=0x9FCF
       [PAODR]=0x0000, [PADAT]=0x79F7
Port B [PBDIR]=0x0BC0F, [PBPAR]=0x0D00E
       [PBODR]=0x00000, [PBDAT]=0x091DC
Port C [PCDIR]=0x008, [PCPAR]=0x000
       [PCSO]=0x8A0,  [PCDAT]=0xB34, [PCINT]=0x000
Receive Ring
        rmd(FF003130): status 9000 length 2E address 7230FE4
        rmd(FF003138): status 9000 length 12 address 7231664
        rmd(FF003140): status 9000 length 12 address 722AE64
        rmd(FF003148): status 9000 length 30 address 722B4E4
        rmd(FF003150): status 9000 length 2E address 722BB64
        rmd(FF003158): status 9000 length 2E address 722C1E4
        rmd(FF003160): status 9000 length 2E address 722C864
        rmd(FF003168): status 9000 length 30 address 722CEE4
        rmd(FF003170): status 9000 length 2E address 722D564
        rmd(FF003178): status 9000 length 30 address 722DBE4
        rmd(FF003180): status 9000 length 30 address 722E264
        rmd(FF003188): status 9000 length 2E address 722E8E4
        rmd(FF003190): status 9000 length 30 address 722EF64
        rmd(FF003198): status 9000 length 30 address 722F5E4
        rmd(FF0031A0): status 9000 length 30 address 722FC64
        rmd(FF0031A8): status B000 length 30 address 72302E4
Transmit Ring
        tmd(FF0031B0): status 5C00 length 25C address 723A134
        tmd(FF0031B8): status 5C00 length 1CF address 723A474
        tmd(FF0031C0): status 5C00 length 1CF address 7239DF4
        tmd(FF0031C8): status 5C00 length 87 address 723A7B4
        tmd(FF0031D0): status 5C00 length 87 address 70BB814
        tmd(FF0031D8): status 5C00 length 87 address 70BCED4
        tmd(FF0031E0): status 5C00 length 87 address 70BBB54
        tmd(FF0031E8): status 5C00 length 87 address 723AE34
        tmd(FF0031F0): status 5C00 length 87 address 70BC1D4
        tmd(FF0031F8): status 5C00 length 87 address 723AAF4
        tmd(FF003200): status 5C00 length 87 address 723B174
        tmd(FF003208): status 5C00 length 87 address 70BBE94
        tmd(FF003210): status 5C00 length 87 address 70BE594
        tmd(FF003218): status 5C00 length 87 address 70BE254
        tmd(FF003220): status 5C00 length 87 address 723B4B4
        tmd(FF003228): status 7C00 length 60 address 723BB34
tx_limited=1(2)
SCC GENERAL PARAMETER RAM (at 0xFF003D00)
Rx BD Base [RBASE]=0x3130, Fn Code [RFCR]=0x18
Tx BD Base [TBASE]=0x31B0, Fn Code [TFCR]=0x18
Rx State [RSTATE]=0x18008440, BD Ptr [RBPTR]=0x31A8
Tx State [TSTATE]=0x18000548, BD Ptr [TBPTR]=0x31F0
SCC HDLC PARAMETER RAM (at 0xFF003D38)
Rx Int Threshold [RFTHR]=0, Frame Cnt [RFCNT]=65176
buffer size 1524
0 overruns
Router---2#show interfaces serial 0
  Internet address is 192.168.1.65/26
  Last clearing of "show interface" counters 00:13:36
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/2/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1158 kilobits/sec
  5 minute input rate 0 bits/sec, 2 packets/sec
  5 minute output rate 5000 bits/sec, 13 packets/sec
     861 packets input, 42168 bytes, 0 no buffer
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     4048 packets output, 194804 bytes, 0 underruns
     7 carrier transitions
Here you go - I personally don't know what all taht means.
And by the way - when I turned on my lab today I couldn't ping host .1 anymore.
Hi ,
I think that this time you forgot the static route on R1, pointing to R2
You can post for the sake of clarity :
show ip route
show ip inter brie
from your 2 equipments
Dan
osatronix
OK.
I figured it out.
Sorry for the hustle and your help everyone.
On the laptop and PC I have also WiFi cards installed. When they are turn on i can't ping from hosts when I turn WiFi connections off, hosts are able to ping each other.
I did not know that can impact connectivity - I discovered it by accident.
Sorry guys - I know I was pain i the a.s.
Can anyone can tell me why it works this way?
Thank you all very much!!!
Probably because of the 2 default gateways that you have on the PC.
As far as I know , Windows OS has an real problem in functioning with 2 default gateways on 2 different network cards.
Dan
osatronix
Thats good to hear that you found the problem. The reason it works this way with PCs that have wireless as well, is when a connection is set as default, and in your case (as in many other laptops) the wifi connection is the default.
The output from last two commands it shows that you have the right cable connected, configured clocking signal on the right end, and that PPP is configured correctly. The rest is for smart people to understand
It was my pleasure to help
All the best
Eugen
