issues with dhcp
hayescd1012
trying to configure multi vlan dhcp addressing, havent been able to get it up and running yet, am i missing something in the config?? Here's my config, i left out the other layer 2 switch configs so i could add a photo of how its setup.
2 Accepted Solutions
I agree with Jon that your diagram is not helpful. What we need at this point is clarification of what the router connects to (what device and what interface on that device) and configs of those devices. Beyond that it may be helpful to know what devices connect to the switch (identifying which port connects to the other switch) and their configs.
Based on what I saw in the configs that you posted I have these observations:
- in configuring the first of your DHCP scopes you start the scope, then you define excluded addresses, then you do the rest of that scope. I wonder if this is a problem and the excluded addresses should be done before you begin the scope.
- in general the router config seems reasonable, the DHCP scopes look ok and the vlan sub interfaces look ok. I see one switch configured with a trunk that would carry the right vlans, are we sure that this is the interface that connects to the router? And I see the trunk configured but do not see the vlans that would be on the trunk configured on any switch.
Rick
Rick
Your diagram shows fa0/5 fro L3-1 going to the ER1 router but there is no fa0/5 in the L3-1 configuration file.
Is this a typo ?
Jon
10 Replies 10
Jon Marshall
Your device names bear literally no relation to your diagram.
Could you have a look and update one of them so things match.
Jon
Rick
Rick
tried my best to get all the interfaces to show up so you can read them all, i hope this helps!! Thanks for all the help so far!
Where is the configuration for L3-1 switch ?
Jon
Only let me post 5 files let me post the rest
Is this a typo ?
Jon
i got dhcp to all of the pc's on s1 and s2 but s3 is still getting 169 addresses. Here are the current configs.
it was the vtp on l3-2 thx to all! dhcp is up on everthing!
Thanks for the update. Glad to know that DHCP is now working.
Rick
Rick
