ISSUES WITH GRE TUNNEL
tomocisco
Hi All,
I earlier started a discussion thread on IP Connectivity issues I was having with my IPSec VPN, the issue was not resolved. I then had to change my router configuration to GRE over IPSec. Pasted below is the sho run, sho crypto session, show crypto ipsec sa and sho crypto isakmp sa for the Head office and remote sites. From the outputs, you will see that the vpn appears down. And indeed I cannot reach resources over the vpn, the ip phones & cameras are not accessible over the vpn connection. But ping results both from the router and from the LAN systems show 100% success.
What could be responsible for this. Ping result shows that there is connection between the two LAN while 'show crypto session', 'sho crypto ipsec sa' and 'sho crypto isakmp sa' indicates that the vpn is not operational.
Also from the SDM, when I test the tunel, this message is displayed: "THE PEER MUST BE ROUTED THROUGH THE CRYPTO MAP INTERFACE. THE FOLLOWING PEER(S) DO NOT HAVE A ROUTING ENTRY IN THE ROUTING TABLE. (1) 4.2.2.2.
Please can someone tell me how to correct this and what route statement I am missing in the config.
SHOW RUN FOR REMOTE SITE:
Current configuration : 6086 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
aaa new-model
aaa authentication login local_auth local
aaa session-id common
crypto pki trustpoint TP-self-signed-1653327508
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1653327508
revocation-check none
rsakeypair TP-self-signed-1653327508
ip cef
crypto isakmp policy 1
encr aes
hash md5
authentication pre-share
group 2
crypto isakmp key 6 OOJAQ address 1.2.2.2
crypto ipsec transform-set ME-VPN esp-aes esp-md5-hmac
crypto map VPN-TO-PH 10 ipsec-isakmp
set peer 1.2.2.2
set transform-set ME-VPN
match address SDM_1
ip ssh time-out 60
ip ssh authentication-retries 2
interface Loopback0
ip address 192.200.200.1 255.255.255.255
interface Tunnel0
description ### Tunnel to LAGOS ###
ip address 192.100.100.2 255.255.255.252
tunnel source 4.2.2.2
tunnel destination 1.2.2.2
tunnel mode ipip
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation hdlc
shutdown
interface FastEthernet0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
ip address 4.2.2.2 255.255.255.248
ip verify unicast source reachable-via rx allow-default 101
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip tcp adjust-mss 1400
duplex auto
speed auto
crypto ipsec df-bit clear
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
interface Dialer1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 4.2.2.1
ip route 192.168.0.0 255.255.255.0 Tunnel0
no ip http server
ip http authentication local
ip http secure-server
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet1 overload
ip access-list extended SDM_1
remark SDM_ACL Category=20
permit ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
logging trap debugging
logging facility local2
access-list 100 remark EXCLUDED FROM NAT
access-list 100 remark SDM_ACL Category=16
access-list 100 deny   ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit udp any any eq bootpc
no cdp run
route-map SDM_RMAP_1 permit 1
match ip address 100
control-plane
end
SHOW RUN FOR HEAD OFFICE:
lag#sho run
Building configuration...
Current configuration : 6499 bytes
version 12.4
no service pad
aaa new-model
crypto pki trustpoint TP-self-signed-3885639516
subject-name cn=IOS-Self-Signed-Certificate-3885639516
rsakeypair TP-self-signed-3885639516
encr aes
hash md5
group 2
crypto isakmp key 6 \]OWLi address 4.2.2.2
crypto map VPN-TO-PH local-address Loopback1
set peer 4.2.2.2
match address VPN-TRAFFIC
ip ssh time-out 60
interface Loopback0
no ip address
interface Loopback1
ip address 1.2.2.2 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
interface Tunnel0
description ### Tunnel t0 PHC ###
ip address 192.100.100.1 255.255.255.252
tunnel source 1.2.2.2
tunnel destination 4.2.2.2
tunnel mode ipip
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation hdlc
shutdown
description ### DOPC PRIMARY LINK ###
ip address 172.16.247.11 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
description ### DOPC SECONDARY LINK ###
ip address 172.16.249.11 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
interface FastEthernet2
description ### Masters LAN Interface ###
switchport access vlan 100
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan100
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
router bgp 65142
no synchronization
bgp log-neighbor-changes
network 1.2.2.2 mask 255.255.255.252
neighbor 172.16.247.1 remote-as 65136
neighbor 172.16.249.1 remote-as 65136
no auto-summary
ip route 192.168.1.0 255.255.255.0 Tunnel0
ip http server
ip http access-class 20
ip nat inside source route-map LAT interface Loopback1 overload
ip access-list extended VPN-TRAFFIC
permit ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
permit tcp any any eq bgp
permit tcp any eq bgp any
access-list 20 permit 192.168.0.9
access-list 100 remark EXCLUDE NAT
access-list 100 deny   ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
no cdp run
route-map LAT permit 1
control-plane
end
SHO CRYPTO SESSION FOR HEAD OFFICE
lag#sho crypto session
Crypto session current status
Interface: Loopback1
Session status: DOWN
Peer: 4.2.2.2 port 500
  IPSEC FLOW: permit 6 0.0.0.0/0.0.0.0 port 179 0.0.0.0/0.0.0.0
        Active SAs: 0, origin: crypto map
  IPSEC FLOW: permit 6 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0 port 179
  IPSEC FLOW: permit ip 192.168.0.0/255.255.255.0 192.168.1.0/255.255.255.0
SHOW CRYPTO IPSEC SA:
lag#sho crypto ipsec sa
interface: Loopback1
    Crypto map tag: VPN-TO-PH, local addr 1.2.2.2
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/6/179)
   remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/6/0)
   current_peer 4.2.2.2 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: 1.2.2.2, remote crypto endpt.: 4.2.2.2
     path mtu 1514, ip mtu 1514, ip mtu idb Loopback1
     current outbound spi: 0x0(0)
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
   local  ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/6/0)
   remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/6/179)
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
   local  ident (addr/mask/prot/port): (192.168.0.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/0/0)
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
SHOW CRYPTO ISAKMP SA:
lag#sho crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id slot status
IPv6 Crypto ISAKMP SA
SHO INTERFACE T0:
lag#sho int t0
Tunnel0 is up, line protocol is up
  Hardware is Tunnel
  Description: ### Tunnel t0 PHC ###
  Internet address is 192.100.100.1/30
  MTU 1514 bytes, BW 9 Kbit/sec, DLY 500000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 1.2.2.2, destination 4.2.2.2
  Tunnel protocol/transport IP/IP
  Tunnel TTL 255
  Fast tunneling enabled
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input 00:00:03, output 00:05:52, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     40062 packets input, 7935632 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     33207 packets output, 4807492 bytes, 0 underruns
     0 unknown protocol drops
PING RESULT TO REMOTE LAN:
lag#ping 192.168.1.1 sour 192.168.0.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Packet sent with a source address of 192.168.0.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 184/320/532 ms
Please can any see where the problem is from the config and how to rectify.
Thanks as always for your contributions.
Tom
9 Replies 9
Edison Ortiz
Here is a good document on GRE over IPSec.
Based on your outputs, you need a lot of fixing so I prefer if you read this document and understand how tunnels are built with IPSec.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a008009438e.shtml
For starters, I recommend peering using the remote peer external interface instead of using loopbacks (which can potentially cause recursive routing, if not careful) as well as using GRE host x.x.x.x host x.x.x.x for the IPSec interesting traffic.
Edison
Hi Edison,
Thanks for the link.
I am studying it.
If I may ask, Can I peer with local IP addresses. The external interface are configured with local addresses from my ISP local address range, the public IP is on the Loopback. Is it possible to peer with these local IP addresses?
I also noticed from the material posted that in the crypto isakmp key statement
"crypto isakmp key 6 xxxxx address 0.0.0.0 0.0.0.0"
the statement ends with 0.0.0.0 0.0.0.0 instead of ending with the address of the peer router (so I think).
Tom
You could set the peer with local IP address but this can't be within the encryption domain.
That's the reason we often recommend using the external facing IP addresses for peering.
The crypto ..... address 0.0.0.0 will allow you to use that key for any peer but you still need to specify the peers under the isakmp policy.
Hi Edison,
Thank you for your contribution.
Below is a rough sketch of my network. I have gone through the material you reffered me to. Please can you give me a sample config I can use for the network below. I want to configure afresh. But I have a problem of how to use the physical interfaces at the Head office for tunneling while still using the Loopback public IP for internet access. The whole thing look confusing. That is why I actually preferred site to site Ipsec.
Tom
Tom
This does present a bit of a challenge and I will be interested in what Edison may suggest. In setting up a tunnel the tunnel source address must be reachable from the peer device. So when tunneling over the Internet it is most common to use the outside address because it is usually the address that is reachable from a peer across the Internet. Since your physical interfaces all seem to have private addresses it would be difficult to tunnel using them.
A second possible challenge about using the physical interface address for the tunnel is the implication that traffic going out those interfaces will be translated by your provider before the traffic actually gets on to the Interenet. Can you confirm whether or not address translation is performed on traffic outbound from the Head Office to the Internet?
Rick
Rick
Are these fictitious addresses?
Or
Do you have another device facing the Internet that is missing on this diagram?
172.16.x.x is not a routable internet address and 4.2.x.x is actually reserved for internet DNS servers.
Again, if you want to learn technologies the proper way, you first have to start with the basics - peer with the external facing interface because as Rick mentioned, it is reachable end-to-end.
If you start peering with a loopback, then routing must take place before encryption.
You also have to exclude the loopback from encryption and this design can become quite complicated.
After you've done a couple of designs, you will learn the best thing is keeping things simple.
Richard Burts
Tom
I believe that the ping is successful because the ip in ip tunnel is configured and working. But the traffic through the tunnel is not encrypted because of the problems in configuring the VPN. I offer the following observations about the issues and possible fixes for the issues:
- the error message about routing 4.2.2.2 which is the peer address from the Head Office. I assume that you are learning that address from BGP which means that you go through interface Fastether0 or Fastether1 to get to the peer. But the crypto map is configured on interface loopback1. For the crypto map to work the traffic to the peer needs to go through the interface that has the crypto map. So in your configuration the traffic to 4.2.2.2 would need to be routed through loopback1. But that is not very feasible. So I would suggest moving the crypto map from loopback1 to the Fastethernet interfaces.
- for the crypto negotiation to be successful the access lists on both ends must match. But your access lists do not match. On the remote you permit only traffic subnet to subnet. But on the Head Office you permit BGP in addition to the subnet to subnet traffic. I believe that is a problem. I am puzzled why you have put BGP into the access list because there is not going to be any BGP to the peer since the peer is not configured to run BGP. So I suggest that you remove the BGP lines from the access list on the Head Office.
- when I configure this type of VPN I specify that the tunnel mode is GRE and my access list would be permit gre host 4.2.2.2 host 1.2.2.2. Your configuration uses tunnel mode ipip and the access list permits subnet to subnet traffic. Perhaps that works. But if you make the other changes that I have suggested and it still does not work then I suggest changing the tunnel mode and the access lists.
Rick
Rick
Hi Rick,
Thanks for your input.
I am still studying the material from the link posted above. I have edited the access list on both side to permit gre host 4.2.2.2 host 1.2.2.2, also I've done away with the BGP in the access list, as suggested.
As for the crypto map, I moved it from the loopback to the Tunnel 0 interface.
Though no noticable change, I am looking at the posted material for  reconfiguration.
Tom
Tom
With the changes you have made I believe that you are going in the right direction but still have some more to do before it will work.
In older versions of IOS you would apply the crypto map on the tunnel interface (as well as on a physical interface). But in recent versions of IOS the crypto map needs to go on a physical interface and not the tunnel.
Rick
Rick
