[ITP7613] Can i disable this notice ?
Texas Hare
Hi all.
I have been using the Cisco 7613 for ITP Sigtran service.
And I had upgrade IXH1 to IRE version.(Cisco IOS Software, s72033_rp Software (s72033_rp-ITPK9V-M), Version 12.2(33)IRE2, RELEASE SOFTWARE (fc2))
but i have seen this message at "wr" command below.
Co1#wr
Building configuration...
[OK]
%NOTICE: unsaved cs7 data exists for MTP3 Route.
         Use exec command cs7 save <xxx> to save listed applications.
I know that this message is noticed for save MTP3 routing table to another location.
So, I attempted to save MTP3 routing table by using cs7 save <storage location> <file name> command.
As a result, I couldn't see that message anymore.
But I really want to know , whether Saving MTP3 routing or did not  i don't wanna see this message anymore.
If you have any other way this "%NOTICE: unsaved cs7 data exists for MTP3 Route."  message.  what should i do?
anikas
Sangrae,
     It looks like you are running into the following defect.
CSCtg35799    Bogus notice to save MTP3 routing update on write mem or reload
This is a bogus notice. The 'write mem' completes and the routing change is saved to startup-config.
This being said upgrading is the only way to resove this issue.
I hope this helps.
