jumbo frames
amms68958
Hi ,
is there any way I can find if an interface supports jumbo frames ?
Using any command ...
Thanks in advance ,
Thomas.
jackyoung
Level 6
Level 6
Check below :
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml
You have to try to input the MTU command under the interface to determine the max. supported size.
Hope this helps.
Or check the module's documentation first... :-)
//Mikhail Galiulin
