Active active load balancing to ISP with 4200 ISR
isaaco001
Level 3
Level 3
Dear support,
Is it possible to have  active active default routes on an ISR 4200 router to two different internet service providers? Kindly share any sample configuration if possible.
Isaac.
Captain HoOmi
Yep, you can use PBR and apply NAT to load balance these two default routes  see below for config example:
https://supportforums.cisco.com/document/32186/dual-internet-links-nating-pbr-and-ip-sla
Please rate the post if find it useful.
** Please rate this post or accept the solution if it helped! :) **
Deepak Kumar
Configuration as like:
ip sla 1
icmp-echo 1.1.1.1
timeout 500
frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 2.2.2.2
timeout 500
frequency 3
ip sla schedule 2 life forever start-time now
track 10 rtr 1 reachability
delay down 10 up 10
track 20 rtr 2 reachability
delay down 10 up 10
ip route 0.0.0.0 0.0.0.0 1.1.1.1 track 10
ip route 0.0.0.0 0.0.0.0 2.2.2.2 track 20
 And Suppose 1.1.1.1 is the default gateway if  ISP 1 and 2.2.2.2 is the default Gateway of ISP2.
Here, If you will face some issue, as Some website is not working then it must enable load balancing as per source or destination using the CEF.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
balaji.bandi
Before addressing the issue, do we need some more information, is this any EBGP/ or static route involved?
Both the links from the same provider ? or different providers? are these links are the same speed.
There are a couple of approaches i can think to best utilize is, split the load into different ISP using your Local subnet or application-based. and do IP SLA tracking and failover link to each other if of the active link fails.
BB
Hi Balaji,
I will be having static routes to two different ISPs,links are on different speeds. thanks for the response.
