10-20-2011 12:16 PM - edited 03-04-2019 02:00 PM
Hello Experts,
We have a L3 gig link between 2 locations (6513 <-->4507). Each location got its own addressing scheme and vlan interfaces on the edge switches.
For our new exchange servers, I received a requirement on having the possibility of single vlan at both locatons. so that the all the replicaton traffic between both location servers (Prod/DR). Ex: Create a new vlan at 6500 site with an addressing scheme 192.168.100.x and having the same addressing scheme vlan stretched over the L3 link to 4500. The link is not MPLS. I read few posts in the forum and seems it is possible if we have MPLS. OSPF is the routing protocol. Please suggest.
6513:
interface GigabitEthernet6/6
description :GIG LINK to DR
ip address 10.60.10.1 255.255.255.252
logging event link-status
speed nonegotiate
udld port aggressive
4507R
interface GigabitEthernet1/1
description :GIG LINK to PROD
ip address 10.60.10.2 255.255.255.252
speed nonegotiate
Thanks in advance
MS
10-20-2011 12:44 PM
MS
Without MPLS you could do this -
1) use 2 vlans - one for peering and one for the exchange servers eg.
vlan 100 - peering
vlan 101 - exchange
2) make the link a trunk link -
int gi/6/6
switchport encpasulation dot1q
switchport mode trunk
switchport trunk allowed vlan 100,101 <-- this is important, you need to make sure only those 2 vlans are allowed on the trunk
same config on 4500 end
3) create L3 vlan interfaces for vlan 100
int vlan 100
same on 4500
int vlan
4) then you peer with OSPF on vlan 100
With this setup communication between subnets/vlans in the 2 sites has to be routed over vlan 100 except for vlan 101 which can be L2 switched.
Jon
10-20-2011 12:53 PM
You need to encapsulate your L2 traffic in order to traverse a L3 backbone.
With a 6500, the only option is EoMPLS which as you stated it requires MPLS in the backbone.
There isn't any option with the 4500 as the edge router.
If you have a budget, you can purchase a pair of router and form a L2TPv3 tunnel between locations.
This will extend your 100.x subnet
These routers can be placed behind the 6500 and 4500 switches so you don't need to change your topology much.
10-20-2011 02:03 PM
Hi Jon and Edison,
Thank you very much for your reply.
Jon, when we make the swithports that are connecting to carrier equipment on both ends as trunks (from L3), I assume
that might cause issues.
Edison, I will check on the L2TPv3 docs. Also, we just found a doc which is showing the 'DAG' need not to be on single
vlan.
http://technet.microsoft.com/en-us/library/dd638104.aspx#NR
Thank you
MS
