l2tpv3 problem on switchport (nim card)
sylvain49
I' ve 2 routers 4321 on 2 sites . I've insert in each routeur NIM-8 card for extend the port capacity.
I've configured L2TPV3 and I would like to configure xconnect on switchport of the NIM-8 card.
It's working between 2 routed ports ( Gi0/0/1) on eauch router.
But it doesn't work between switchport  ... xconnect seems correct but no communication is possible.
How it's possible to do working L2TV3 on switchport
--> L2TPv3 xconnect is not supported on an EtherSwitch module
Check the section 'General L2TPv3 Restrictions' in the linked document below:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/wan_lserv/configuration/xe-3s/wan-lserv-xe-3s-book/wan-l2-tun-pro-v3-xe.html
Thanks for your reply ... so i'm studing other card do you think that l2tpv3 will work with :
Cisco SM-X Layer 2/3 EtherSwitch Service Module ?
Of course I will change the router reference
