L2TPV3 pseudowire 1900 1921 Universal image
neil grant
Hello Guy's come to a bit of a block in the road on a network im building ,all is going well except i need to build a pseudowire to backup our primary L2 circuit, I labbed this with some 3745's but the kit we are using is the 1921, with the universal image how do i go about upgrading functionality to allow this
Lab Config:
pseudowire-class L2DRPATH
encapsulation l2tpv3
ip local interface Serial0/0
interface FastEthernet1/0
no ip address
speed 100
full-duplex
no cdp enable
xconnect 10.10.10.2 101 pw-class L2DRPATH
but neither
pseudowire-class under configuration mode, or xconnect under interface configuration mode is known.
Good ducmentation for people wanting to do the same:
https://isc.sans.edu/diary.html?storyid=8704
Version :
"usbflash0:c1900-universalk9-mz.SPA.150-1.M5.bin"
Many regards Neil
Regards Neil http://uk.linkedin.com/pub/neil-grant/20/5b0/267
6 Replies 6
Edison Ortiz
You need to purchase the Data+Security license.
Edison
Thanks for the info, once i get the license can I perform the upgrade from the CLI? is there any useful documentation?
Cheers neil
Much appricated
Regards Neil
Are you able to configure the command 'pseudowire-class' after upgrading the IOS.
Hi Edison
Can you please share document mentioning that 'pseudowire-class' is supported in data + security license in ISR G2 Router.
