L3 switch or router for Comcast fiber (EDI)
rmathewsjr55
Hello. I would like some suggestions on the following. We have purchased Comcast Ethernet Direct Internet (EDI). Fiber is run directly to the CPE. Comcast is providing a Ciena LE-311 switch that handoffs the fiber to RJ-45 copper. Does anyone have experience with this device? Should we use a L3 Switch or Route to connect to this? My concern is security and throughput. We have 100Mbps connection but planning in the near future to go to 1Gbps. This service is for corporate Internet access. Thank you.
Joseph W. Doherty
Disclaimer
The      Author of this posting offers the information contained within this      posting without consideration and with the reader's understanding   that    there's no implied or expressed suitability or fitness for any    purpose.   Information provided is for informational purposes only  and   should not   be construed as rendering professional advice of any  kind.   Usage of  this  posting's information is solely at reader's own  risk.
Liability Disclaimer
In      no event shall Author be liable for any damages whatsoever    (including,   without limitation, damages for loss of use, data or    profit) arising  out  of the use or inability to use the posting's    information even if  Author  has been advised of the possibility of   such  damage.
Posting
For features, router normally wins.
For performance, L3 switch normally wins.
For a gig link, almost any current L3 switch with gig port would have the peformance.  For a router you'll want (in [debatable] ascending performance) 3925, 3945, 7200 w/G1, 3925E, 7200 w/G2, 3945E or ASR 100x.  (Which would be best depends on actual expected traffic load and feature use.)
5 Replies 5
mvsheik123
Level 7
Level 7
Ciena should work just fine.My ISP ( and other P2P pvt link provider as well) uses the Cienas and we never had any issues. What you need to connect, depends on how your infrastructure. ex: BGP routing etc : Router port and if its default route use your firewall outside interface.  You need to work with Comcast on your router/fw (speed/duplex) settings and how you are planning to access internet.
hth
MS
paolo bevilacqua
What's your budget ?
Joseph W. Doherty
Disclaimer
Posting
Thank you all for your help. We will move forward with placing a L3 switch behind the Ciena LE-311 switch. With this in place, can we configure the L3 switch to provide load balancing if we were to connect another high speed 100Mbps ISP service in the future?
Disclaimer
Posting
Assuming you'll be routing, a L3 switch should be able to load balance outbound.  Load balancing inbound, if you're doing Internet, may be difficult.
