01-22-2020 04:36 AM
What are the stacking types?
Is it necessary to present a stack port on the switch to configure it as stack or we can define switches a stack individually on switch
01-22-2020 04:49 AM
here is basic understand of stacking : (it is small business switch but concept all same)
you need to have stacking port available - most of them does - some switch have smart stacking.
here is how to configure :
01-22-2020 06:26 AM
abdul.qadir5001,
There are two main types of stacking ports:
1. Dedicated stacking ports
2. Switch data ports
Dedicated stacking ports are physical ports that can only be used for one purpose - switch stacking. They often have different form-factor, than the standard data ports. These kind of ports don't require any kind of extra configuration, because as I said their only purpose is to link stack members to each other.
Switch data ports can be used to emulate stacking over the normal Ethernet ports. This is a "poor man's stacking". It is less efficient, as it takes away available data ports and usually it has lower bandwidth rates. For example, dedicated stacking ports on 3750G switches have bandwidth capacity of 16Gigabit/sec per port, while data ports only go up to 1Gig. Newer switches have even faster stacking ports.
01-22-2020 10:10 AM
