01-06-2013 09:05 PM - edited 03-04-2019 06:36 PM
Hi Team,
I have certain queries. As mentioned in topology I have two locations (Location A & Location B). I have data MPLS lease-line to connect this two location. Thing is that i want to configure Same subnet IP address on LAN of both locations.As my machine dont have a facility to configure default-gateway ,so i need to specify same subnet IP on both sides.Please suggest me and help me to do so.
I want to communicate Location-B IP 172.16.15.1 to Location-A IP 172.16.15.5.
Dual Nat is not possible as MY machine dont have a facilty to assign default-gateway.
Please find the attached topology
01-06-2013 10:07 PM
Hello Pawan
I think pseudowire is your friend. It will extend your LAN to the other side.
Find more information here : http://blog.ine.com/tag/pseudowire/
Please rate this post if helpful
Shamal
02-02-2013 01:18 AM
You should never do that.
Two locations, two subnets. And everything will work easy and surely.
03-10-2013 07:11 AM
Depends upon the equipment you have available...
If you just have a couple of routers then you can configure them (and wan link) as a bridge.
if you have switches on each side then you could set the wan link as a trunk.
Neither of these is a recommended configuration for wans but both will work, especially for a small network.
03-10-2013 07:44 AM
Hi Pawan,
You may consider OTV as well if you have ASR or Nexus switches as well
03-10-2013 11:33 AM
HI,
You can have L2 VPN lease-line link to connect these two location form your ISP. and Terminate that Link Dircelty into Your switches, in this u can have same subnets between two locations.
*** Do Rate Helpful Posts***
08-02-2013 01:50 AM
Hi Pawan,
I too believe, OTV is your friend and works as a wonderful solution. If there is reachability between the routers at locations A and B [external interfaces], that is more than enough you need not worrry about anything. We can make this work, all you need are asr1k or nexus [don't know the flavor] routers. Even CSR1000V [virtual-router] can be used for this purpose.
