Latency on WAN link
All can you please help with the following
Site A is connected to Site B using two 1 Gig LES lines the two site are physically 60 Miles apart.
When I ping Site B from Site A I can see delays of 5ms on the pings.
Is that normal ?
If yes can we make any config Changes or additional hardware to reduce the latency ?
If we have latency of 5ms whats the maximum Throughout we can have over a 1 Gig interface if we are coping a file from one server to another considering the server is not a bottle neck ?
Any help is much appreiciated
2 Accepted Solutions
paolo bevilacqua
May be telco has intermediate devices increasing latency, ask them.
You cannot do anything about it.
5 Replies 5
paolo bevilacqua
Hi Paolo,
Many Thanks for your response
I have been in touch with the ISP and they confirmed these delays are normal for two SItes 60 miles apart.
Just wanted confirmation from experts on this Site.
I believe if we have latency backups will run slow between the two sites is there a way we can calulate the through put based on the LAtency we have
For me it is 5ms
Thanks in Advance
Many Thanks  vmiller
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
5 ms for 60 miles - well fiber physical delay is about 5 us per Km, so 60 miles would be a little less than 100 Km, double for RTT and latency should be about 1 ms.  So, 5 ms ping seems a tad high.
If you're doing bulk file copies, you should be able to drive the link to gig capacity.  With standard size (1500) Ethernet and TCP, believe you should obtain close to 97% of link speed.  (Note: to obtain this TCP rate, your receiver needs to have RWIN large enough to support the BDP; and very, very few drops.)
