Layer 2 Tunneling Protocol (L2TP) over IPsec on ISR 1921
ElwinMkanyika
Guys,
Is it possible to configure Layer 2 Tunneling Protocol (L2TP) over IPsec on a cisco router like 1921 ISR? This link shows basically what i want to achieve but instead of an ASA, i would like to use just a router with sec....Please help? Is it possible?
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807213a7.shtml
Torsten Jahnke
Congratulation m8! :-)
This is not a solution. This is an challenge ;-)
In short answer, yes - it is possible.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080093f6f.shtml
Thanks a lot!
Torsten Jahnke
founder and inventor of keweonDNS
Hi Torsten,
I saw that link. The issue is that i only have 1 router...not two as in the solution that you provided.
I would like a solution like this:
XP - Internet - Router - Corporate network
jurodri3
Hello Mr. Mkanyika,
Thank you for your question.
However, the Small Business Support Community is limited to Cisco Small Business Products and the 1921 router is considered as an Integrate Services product.
You might consider to ask this question at Enterprise forum to get a better response.
http://www.cisco.com/en/US/products/ps10819/index.html
Best regards,
Diego Rodriguez
Cisco Small Business Community Engineer Best regards.
