leased line backup problem
senthil.gabriel
Plz help me out leased line backup problem-
i configuerd ISDN for Leased line backup but after Leased line goes down Traffic is not routed thro ISDN line .when i put this -
ip nat inside source list 101 interface bri0 overload
Then traffic is routed through ISDN but after this leased line is not working so plzz tell my right configrutation for this iam sending the configrutation with the attachment
16 Replies 16
hi
spremkumar
ya i already did the same but i need to check with isp
Dear senthil
As i have suggested u earlier
taking primary route for lease line
use command
ip nat inside source list 101 interface serial0 overload
delete loopback interface
secondly in bri0 config ip address is negotiated so check what ip address u r getting . try to ping an internet ip drom ur router when isdn is active
if it works then
just prepare access list 102 permitting same internal network and overload it with bri0
problem u r facing can happen if isp failed to put seconary route pointing bri0 .u can check this through as u have put this command
ip nat inside source static 192.168.5.20 59.145.X.X extendable.
just ask any 1 of them to ping this ip 59.145.X.X from outside . when lease line is down . if it's doesnt ping that means isp had not inject secondary route for same network 59.145.a.b/29 will be i guess. ok try this and let me know
