Legacy DDR
alsayed
i have a project, an client has only 2 Public IP addresses, i want to use Network address Translation (NAT)and we want to Use legacy DDR to connect to the ISP with PPP encapsulation.
How can i achieve a better config/Setup for this project?
who face like this setup plz provide necessary info...
10xs for ur help
7 Replies 7
spremkumar
Level 9
Level 9
Hi Sayed
You can configure something like Overload(PAT) to achieve your requirement.
You need to create inside and outside statements respectively.
Once you are done with the same do create an access-list permitting your local lan block to access any.
while creating the nat statement you need to make sure you are overloading onto the interface which connects you to the outside world..
also refer the below link for more info on the same..
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_white_paper09186a0080091cb9.shtml
regds
Hi spremkumar!
10xs for ur reply.but what about the connection to internet Thr ISDN
10XS
what is your connection type?
BRI/PRI and how you are dialing router to router or any numeber (to any RAS)?
HI Mate!
we have BRI Interface and WE SHOULD lagacy DDR WITH Encap PPP
10XS
any Help here regarding legacy DDR With ppp encap to ISP
10xs
hi rajivrajan1
10xs for ur reply!
