Legacy NAT issue against NAT virtual interfaces
esteban.r
Dear Community
I have to install routers IR809 on several sites covered by 3/4G for monitoring and maintenance purpose. These routers must be connected to the monitoring center (MC) by EasyVPN through 4G network. (We cannot setup VPN IPSEC L2L because ISP can only provide private IP for 4G connection)
I need to monitor equipments on these sites (mainly by ICMP and SNMP) from the monitoring center but the equipement on-site don't have the IR809 as default gateway. As a result, I must NAT traffic coming from the MC to one IR809 interface with an IP in the same subnet than my equipment on my IR809, allowing the monitoring center to initiate the communication with the equipment
On my lab, the EasyVPN is correctly established between the MC and the IR809 acting as the EsayVPN client.
1- If I configure my equipement on site to have the IR809 as default gateway, it works properly. I can send/receive traffic from both sense
2- If I configure my equipment to have another router than my IR809 router as default gateway and when applying the legacy NAT configuration "ip nat inside/ip nat outside" on interfaces, it works properly as well.
My issue concerns "NAT Virtual interface" which is configured by default in the router configuration. If I reset the VPN connection or reload the router, I loose my legacy NAT configuration. I don't understand why the router come back to the default NAT configuration.
Your assistance would be helpful
Thanks in advance
your default route points to Cellular0, which is the NAT inside. This might be the problem. I cannot really figure out from your original post what your logical setup looks like and what NAT is supposed to do.
At the very least, you need a default route pointing to a NAT outside interface, which in your case is GigabitEthernet0.
Try and change the default route to:
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0
and check if at least the config stays the same after reload (obviously save it to memory first)...
5 Replies 5
--> If I reset the VPN connection or reload the router, I loose my legacy NAT configuration. I don't understand why the router come back to the default NAT configuration.
Post both the configuration before and after the reload.
Hello Georg
Thanks for your prompt reply.
Please find configuration of EZVPN client before  reload and after reload here-enclosed
 Hereunder the "show version" output:
Cisco IOS Software, ir800 Software (ir800-UNIVERSALK9-M), Version 15.5(3)M4a, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Thu 06-Oct-16 15:56 by prod_rel_team
ROM: Bootstrap program is IR800
RTR-MON-VLLB uptime is 43 minutes
System returned to ROM by CLI initiated reload at 07:03:58 UTC Thu May 31 2018
System image file is "flash:/ir800-universalk9-mz.SPA.155-3.M4a"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco IR809G-LTE-GA-K9 (revision 0.0) with 373760K/52224K bytes of memory.
Processor board ID FCW211500L2
Last reset from CLI initiated reload
FPGA version: 2.0.0
BIOS: version 8 Production
BIOS: date[YYYY/MM/DD] :[2015/6/2]
2 Serial(sync/async) interfaces
3 Gigabit Ethernet interfaces
8 terminal lines
2 Cellular interfaces
DRAM configuration is 72 bits wide with parity disabled.
256K bytes of non-volatile configuration memory.
976562K bytes of ATA System Flash (Read/Write)
250000K bytes of ATA Bootstrap Flash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*1        IR809G-LTE-GA-K9      FCW211500L2
Suite License Information for Module:'ir800'
Suite                 Suite Current         Type           Suite Next reboot
Technology Package License Information for Module:'ir800'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      securityk9           Permanent      securityk9
data          datak9               Permanent      datak9
Configuration register is 0x102
Hello George
In my first post, I attached  the diagram of  my setup.
The Monitoring Center  use IP subnet  192.168.100.0/24
The Monitoring system is 192.168.100.1 with default gateway 192.168.100.1 (which is the EZVPN server router)
On the other side:
My Equipment to monitor is 192.168.1.2 with default gateway 192.168.1.1 that does to belong to any interface of my EZVPN client router, it 's another router.
However my EZVPN client router  has an IP in the same subnet than my equipment which is 192.168.1.10
That's why I need to translate IP of traffic from the monitoring system to router interface, otherwise I wont get any reply.
I cannot change the default route to point to gi0/0. Otherwise I can't be able  to set up the VPN. I tried it in lab with GNS3 and it is working as expected.
If you have other idea regarding the  requirement, feel free to propose
Hello George,
You're right.
If I specified the default route on the Cellular0 interface, then NVI will automatically consider the cellular0 as outside NAT. When I remove the default route or any static route on this interface, then I can see the legacy NAT config in the running config. However, I cannot setup my VPN anymore with my EZVPN server
Is there any way to globally disable NVI?
